Author Topic: Moree speeed  (Read 3407 times)
Offline RyanManning
Moree speeed
« on: 10 March 2009, 21:49 »
I love my golf but it is only a 1.8. i wanta keep the car but i want more speed is there anything that i can do that wont cost over a grand and will give me some more poke?
thanks
Josho
Re: Moree speeed
« Reply #1 on: 10 March 2009, 21:50 »
Not a lot. You could spend a few hundred on uprated cams, but won't give you loads more power.
Most reccomended thing to do is a panel filter, smooth the airbox and then drill holes in the bottom of it near the wing. Then a decent exhaust system.
Offline shepgti
Re: Moree speeed
« Reply #2 on: 10 March 2009, 21:51 »
turbo/turbo charger for under 1k
Offline RyanManning
Re: Moree speeed
« Reply #3 on: 10 March 2009, 21:54 »
turbo for under 1k?? surly not?
yeah i got a reflex exhaust on it .. where do i drill holes?? there any guides ?
cheers
Offline shepgti
Re: Moree speeed
« Reply #4 on: 10 March 2009, 21:55 »
cheers
depends really but by no means worth it...
guide to airbox http://forums.vwvortex.com/zerothread?id=3063843
Offline RyanManning
Re: Moree speeed
« Reply #5 on: 10 March 2009, 22:01 »
Thanks man
Why is it not worth it? surly a turbo will drasticly improve the speed
Offline Mikester
  • Civic Type R
Re: Moree speeed
« Reply #6 on: 10 March 2009, 22:04 »
Thanks man
For a mile, then it blows up. Need to make the engine stronger before you increase the boost, unless you run it at stupidly low boost, getting not much extra power.
Offline shepgti
Re: Moree speeed
« Reply #7 on: 10 March 2009, 22:04 »
Thanks man
of course but you would loose nearly all you spend on it and insurance would go up alot... and i assume insurance is an issue as you have a 1.8 and not a 16v..
Josho
Re: Moree speeed
« Reply #8 on: 10 March 2009, 22:05 »
Yeah but then you have to upgrade a lot of other things to cope.
Offline DrewGTI
Re: Moree speeed
« Reply #9 on: 10 March 2009, 22:07 »
Not as clued up as most on here but surely mods like that would hurt on the insurance and also more speed would mean better brakes etc too. .
