Author Topic: engine woes  (Read 971 times)
Offline shepgti
engine woes
« on: 10 March 2009, 13:45 »
right my engine is making a really bad tapping noise now, educated guess would suggest the tappets (now what are they? where are they located? do they fail?  :undecided:)
all input welcome!
Josho
Re: engine woes
« Reply #1 on: 10 March 2009, 15:00 »
Is the oil pressure OK and is it topped up?
No flashing lights on the dash?
Offline spunkymonkey
  • Tepidly moist! That's what that is!
Re: engine woes
« Reply #2 on: 10 March 2009, 15:13 »
tappets are little hydraulic dampers that fit between the cam and tops of the valves, they have a tiny hole that allows oil to fill up to give a damping effect. when the they give up which isnt uncommon they give off a tapping sound. If it hasnt had a oil change do it and use a good quality oil and give it a good flush. They arent a major job but not a 5 min one either.
Offline shepgti
Re: engine woes
« Reply #3 on: 10 March 2009, 15:20 »
thanks for that spunky, guess ill give it an oil change see if it changes anything.
Offline Len
Re: engine woes
« Reply #4 on: 10 March 2009, 15:49 »
Certainly worth a try as its far cheaper than having to take the head off etc.
Oh didnt somebody sy you can replace tappets without taking head off and removing valves? :undecided:
www.sas.org.uk
www.the-ace.org.uk
Re: engine woes
« Reply #5 on: 10 March 2009, 16:53 »
I think you can, i was under the impression it was cam out but you dont need the head off. If it need them replaced its an excuse for a cam belt if it hasnt had one. You will need all 8 replaced though! Only a few quid each i would of thought!
