Author Topic: '99 gti turbo, noisy heater, water leak and others ??  (Read 2335 times)
Offline blown the case
Hi there, new to the forums so bear with me, just sold a worn out mk2 gti and bought a mk4 gti t, seems a good car  :undecided:  but I have a few little problems, firstly there is a constant tap tap noise from the heater motor, its got digi climatronic & briefly stops when you press the recirc button then starts up again at a slightly different tone, even sounds when the engine & cliamte control is switched off ? I presume a replacement heater motor would sort it, if so any one ever removed / replaced one ? any ideas ? HELP !!!
Secondly I have noticed over the last few rainy days a slight drip of water below the glove box that deposits on the mat in the footwell, you can actually see a drop forming on the plastic panel below glove box, have checked its not coolant, as no sweet taste. I have removed pollen filter & housing below, didnt see any issues there so replaced it & ran a bead of mastic around the edge, but low & behold it still seems a little wet again today ? HELP  :cry:
The previous owner installed a carbon fibre effect air box cylindrical type with a stainless steel pipe that discharges down by the chassy leg, so when you back off the turbo makes a twitter sound ? I always prefer to run cars standard and I am worried that an aftermarket device like this could damage the turbo or cause bad running, has any one any experience ?  :cool:
Cheers for any feedback...............blown
99 GTi 1.8 20 valve Turbo : Forge DV, R Tech remap, Carbon Air box / intake
Offline jonnyturbo
Re: '99 gti turbo, noisy heater, water leak and others ??
« Reply #1 on: 10 March 2009, 14:04 »
the water leak could be a cracked scuttle tray. Lift ur bonnett. And its under the windscreen passenger side
« Reply #2 on: 10 March 2009, 14:06 »
Hey fella, cheers, ive had a look & it seems fine ?
Offline Rhyso
« Reply #3 on: 10 March 2009, 18:38 »
sounds like your heater matrix could be on the way out - its located behind the glovebox
Offline perd999
« Reply #4 on: 11 March 2009, 12:58 »
Im afraid that if it is teh heater matrix = BIG job...v :sad:
Offline ben1.8T
« Reply #5 on: 11 March 2009, 13:46 »
How much did you pay for it?
Golf SOLD. Replaced with a Yamaha Raptor 660 quad and loving it. This will be replaced in August with a Raptor 700. Sold the quad now got a Vectra GSI 2.5 V6 and its the nuts.
Brands Hatch massive. MEMBERSHIP ACCEPTED!
Offline dai-cymru
  • 1989 MK2 16V
« Reply #6 on: 11 March 2009, 14:08 »
very big job im afraid, i have a heater matrix and motor complete from a climate control car, very involved job changing it
