Author Topic: MK4 rear calipers  (Read 1458 times)
Offline ReDBull
MK4 rear calipers
« on: 10 March 2009, 12:22 »
I have a pair of rear calipers for a MK4 golf to fit on to my MK2 golf GTI. However one of the pistion seals has been damaged at some point and needs replacing. I've asked at GSF and they told me I would need to replace the hole caliper. Is this true? If so would the seal from the MK2 caliper that it is replacing fit?
03 210 Seat LCR. Badger5 V2.2TIP, Fordge 007p, Wellycooler, Quaife ATB LSD, Nuespeed ARB's, KW Clubsports, 330mm discs, 3" turbo back de cat and still on the standard map!
My project thread: http://www.golfgtiforum.co.uk/index.php?topic=241116.0
Re: MK4 rear calipers
« Reply #1 on: 10 March 2009, 12:54 »
go to VW, they'll sell you a rebuild kit for it. ideally you need a proper caliper rewind tool though
Offline ReDBull
« Reply #2 on: 10 March 2009, 13:18 »
Thanks just phoned VW the kit is £18. Have the rewind tool looks like someone has used a srew driver in the past. Thanks for the help.
« Reply #3 on: 10 March 2009, 15:02 »
ah that could be bad news! if you work the handbrake lever the piston should gradually wind out, if not whoever messed about with it last has trashed the handbrake mech!
