Author Topic: mk2 5-speed gearboxes  (Read 3436 times)
Offline Broken_bearings
« on: 01 July 2003, 18:36 »
The input shaft bearings have started to make a bit of noise so I am looking for a replacement 2nd-hand gearbox. The car is a 1991 MK2 Golf Driver 1.8 (GU series engine) and the gearbox code begins with AZT. Is this an "020" gearbox?
I have been told by a local specialist (S.Devon area) to try and get hold of a gearbox from a 1.8 GL as it will give taller gears and better fuel economy.
Any idea what the gearbox code is I should  be looking for?
Re:mk2 5-speed gearboxes
« Reply #1 on: 01 July 2003, 18:39 »
Sorry I typed the gearbox code wrong . The car is fitted with code beginning "ATH".
Offline richandhazel
« Reply #2 on: 01 July 2003, 19:10 »
'taller gears and better fuel economy'..........I assume that's at the expense of performance and acceleration then.
Anyway, for what use it is here is the online ETKA for your gearbox:-
http://www.elcats.ru/audivw/vag5.asp?subm=%CF%EE%E8%F1%EA&btsnr=083-00&cid=110
You'll probably have to copy and paste the whole link into your address bar........not all of the link has highlighted.
« Last Edit: 01 July 2003, 19:12 by richandhazel »
