Author Topic: Annoying accelerating problem  (Read 2427 times)
Offline ian00uk
« on: 09 March 2009, 21:02 »
hi all
when i put my foot down the engine revs high but not in smooth way like normal car should. it jumps right up to high revs but the car doesnt accelerate with it then when u let the accelerator off then the car jurks forward. its especially embarrasing when overtaking because it sounds real bad. its hard to explain.
ive tried changing the maf but that hasnt worked.
Offline richw911
Re: Annoying accelerating problem
« Reply #1 on: 09 March 2009, 21:09 »
hi all
any fault codes?
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
« Reply #2 on: 09 March 2009, 21:10 »
Sounds either like a slipping clutch or a dirty throttle body?? :undecided:
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline Rhyso
« Reply #3 on: 09 March 2009, 21:11 »
slipping clutch sadly
Offline ian00uk
« Reply #4 on: 09 March 2009, 21:12 »
no nothing. i checked it over and had split in pipe because my boost was well down and now the boost is back to what it use to be but this problem is still happening.
Offline ian00uk
« Reply #5 on: 09 March 2009, 21:13 »
slipping clutch that sounds bad. is that expensive to sort?has anyone else had this problem before?
Offline richw911
« Reply #6 on: 09 March 2009, 21:13 »
just re read the post as said sounds like clutch slip
Offline richw911
« Reply #7 on: 09 March 2009, 21:14 »
Which engine do you have?
Offline Rhyso
« Reply #8 on: 09 March 2009, 21:15 »
look in the info section for the G60 thread (assuming yours is a 1.8T)
most people have had the problem and you're looking around £400 or so all in
Offline ian00uk
« Reply #9 on: 09 March 2009, 21:15 »
ive got mk 4 1.8t aum engine
