Author Topic: FMCL007P VS FMCL007PA  (Read 2805 times)
Offline Voodoo-Music
« on: 09 March 2009, 18:52 »
Basically whats the difference as it does not explain on the forge webiste, i understand the latter is vaccum adjustable but what benefit is there
Offline Rhyso
Re: FMCL007P VS FMCL007PA
« Reply #1 on: 09 March 2009, 18:55 »
good question
email Forge for an answer cos i don't know  :laugh:
though looking at the info it looks like you can adjust it  - i presume to fine tune things  :undecided:
EDIT
just read it again - looks like you can modify the position of the vaccum tube so if yours for some reason is an awkward fit you can change the position to stop the tube being pinched / kinked  :nerd:
« Last Edit: 09 March 2009, 18:57 by Rhyso »
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #2 on: 09 March 2009, 20:35 »
interesting  :wink: i wasn't sure either  :laugh: least you've cleared that one up rhys :afro:
2000 Mkiv GTi 1.8T AGU
Offline Rhyso
« Reply #3 on: 09 March 2009, 20:37 »
i'm not 100% i am right but reading it thats how it read back to me  :undecided:
  • "1.8T AGU"
« Reply #4 on: 09 March 2009, 20:44 »
:afro:
  • "1.8T AGU"
« Reply #5 on: 09 March 2009, 20:50 »
just had a read on the forge site and i'v come to the same conclusion  :wink:
Offline Rhyso
« Reply #6 on: 09 March 2009, 21:10 »
good stuff - glad i won't be the only when we're told its wrong  :laugh: :laugh:
kind of makes sense to allow you to position the pipe just right - stops the pipe getting trapped  :smiley:
Offline richw911
« Reply #7 on: 09 March 2009, 21:19 »
For use with different TIP's that change the DV position - possibly  :undecided:
« Reply #8 on: 10 March 2009, 09:01 »
OK, been in contact with forge about this and got the answer.
Basically there is a difference in the valve due to the adjustment but not for our cars.
Apparently porsche needs to have the vaccum adjustment in the valve but we dont. Its only on the vw part as it fits all the vag engines but the vaccum adjust is of no earthly use so there advice is ALWAYS buy the 007P and save your money
Was bugging me that  :grin:
