Author Topic: How often....  (Read 833 times)
Offline admc6
How often....
« on: 09 March 2009, 18:15 »
..would you expect your crankshaft angle sensor/engine speed sensor to fail?
Mine seems to be showing up as a fault (which would explain the non start and cutting out), but i had only had one put in June 08  :huh:
Offline boneybradley
  • Back in a Mk3...
Re: How often....
« Reply #1 on: 09 March 2009, 18:18 »
hard to say and i would expect them to last years but check the wiring too as this will show as a fault with the sensor!! (and seems a common issue!)
Offline admc6
Re: How often....
« Reply #2 on: 09 March 2009, 18:23 »
Would having a damaged wire to it cause the same cutting out issues as a faulty sensor?
  • Back in a Mk3...
Re: How often....
« Reply #3 on: 09 March 2009, 18:26 »
yes and it would give the same fault code too!
Offline admc6
Re: How often....
« Reply #4 on: 09 March 2009, 18:29 »
Oh ok, i will look into that.
