Author Topic: MFA, is this right?  (Read 2022 times)
Offline dan_apps
  • too low for british roads!
MFA, is this right?
« on: 09 March 2009, 11:38 »
just noticed MFA seems to be working fine apart from the mpg reading, average about 30mpg on motorways etc usually but since i changed the clutch cable whatever im doing i.e. pootling in traffic or flat out down the M4 it says im not doing more than 14mpg?!? am i just expecting too much from 18 yr old technology or have i broken something?  :embarassed:
cheers Dan
Offline madmanluke
Re: MFA, is this right?
« Reply #1 on: 09 March 2009, 11:59 »
i also have this issue, was working fine (well i was excepting the read out at around 28 mpg on average) but has since stopped working for no reason it seems and now reads about 12mpg at an absolute best!!!  i believe it works using a vacuum tube to the back of the clocks? could this be a perished pipe/leaking?
any help would also be appreciated!
Offline JC
  • Back in the North.
« Reply #2 on: 09 March 2009, 12:14 »
cheers Dan
yes  :wink:
Offline Ben Lessani
« Reply #3 on: 09 March 2009, 13:11 »
Mines the same, its off by a factor of 3 - only ever shows 13mpg. My pipes alright - I would have thought if it were leaking the sensor would show less vacuum > more miles, which should be higher mpg.
I've been lead to think its just the sensor on the back of the clocks itself.
Offline maxp
  • J reg 8v digi gti
« Reply #4 on: 09 March 2009, 13:58 »
Mine used to read about 9-12, got the vacuum pipe fixed and its now reads 35ish
Offline dan_apps
« Reply #5 on: 09 March 2009, 14:37 »
ok so looks like ive fooked it then, i belive there is a clear pipe that runs throught the hole from the engine bay to the cabin, must have been where i rammed the new clutch cable through! ah well
thanks guys :afro:
Offline JC
« Reply #6 on: 09 March 2009, 15:03 »
 :grin:
Offline snowley
« Reply #7 on: 09 March 2009, 15:51 »
I have the exact same problem too!!
guess I will look into getting that sorted then!!!
Offline cняis
« Reply #8 on: 09 March 2009, 21:01 »
check for a clear vacuum tube near the ignition coil on the bulkhead, it slips inside a braided hose. mine came out of the braided hose and was reading 12mpg  :undecided:
i stuck it back in and straight back up to 35/40 mpg
Offline muppet
  • 1.8 16v Oak Green :D
« Reply #9 on: 09 March 2009, 23:05 »
got the same problem and this sounds dumb but im knew at this and just wanted to ask where the clear vacuum tube be as in wheres the frigging ignition coil  :laugh: ive had a quick peak under the bonnet and i cant for the love of life think of what im looking for!!!
