Author Topic: manifold to downpipe studs  (Read 884 times)
Offline richard s
« on: 08 March 2009, 15:06 »
does anyone know the size of the manifold to downpipe studs ie m10x30
cheers
Offline russ-vdub
  • Once a Dub, Always a Dub
Re: manifold to downpipe studs
« Reply #1 on: 08 March 2009, 15:36 »
M10 they most definately are, the length doesnt matter too much, just make sure its as big but if not bigger to be sure.
Why may ask, you re-studding a manifold? Personally just drill them out and use stainless bolts and two nuts, easier to fit imo, except you have to make sure its lined up properly first
Offline richard s
« Reply #2 on: 08 March 2009, 15:51 »
i want to fit a spacer so need to know original size then can find some longer ones
Offline trev8v
« Reply #3 on: 10 March 2009, 23:20 »
M10 X 1.5 pitch I believe - if you want to replace them with longer studs then getting a good quality tap might be a good idea (cheap ones wont cope with manifold material)
Offline paultownsend
« Reply #4 on: 11 March 2009, 12:40 »
you need longer studs for a spacer. i used a 10mm spacer for my 2e conversion, and with gasketts it only 'just' fits.
1 boly is however now missing!
Offline richard s
« Reply #5 on: 11 March 2009, 21:01 »
so m10x?x1.5 pitch
cheers guys just need the length now
