Golf mk2
Rear wheel bearings
Topic: Rear wheel bearings (Read 969 times)
Martz
Forum Supporter
Rear wheel bearings
08 March 2009, 14:21 »
Hi
Does anyone know if the rear wheel bearing are on there way out, will this cause the rear of the car to wobble at speed? Project Ghetto is doing exactly that.
Not to confident taking it for a good thrashing just yet!
Martz
Wayne
Sir Postalot
Re: Rear wheel bearings
08 March 2009, 18:44 »
Yes maybe or rear axle bushes.
Also worth checking for a buckled or out of balance wheel.
Ben Lessani
The poor mans MK2 Haynes author
08 March 2009, 18:55 »
Could also be a loose stub axle nut
Martz
Forum Supporter
08 March 2009, 22:08 »
Quote from: Ben Lessani on 08 March 2009, 18:55
Good point, had that on the Diesel. Will check tomorrow.
Martz
Forum Supporter
09 March 2009, 21:32 »
Ok, so I checked the rear nuts and found that they were loose. From what I understand they are only to hand tight? Is this correct?
Steve_B
09 March 2009, 21:47 »
That's right, the washer underneath should just be able to move freely.
Golf mk2
Rear wheel bearings
