Author Topic: fuel pump not primeing  (Read 1855 times)
Offline 0191joe123
« on: 08 March 2009, 10:12 »
rite a just went to put sum petrol in the gti ,put petrol in went to pay and came bck and car wouldnt start engine just turning and turning and carnt here the fuel pump prime has done this a couple of times now but if i sit and turn the ignition on and of it eventualy primes and the car starts av changed the fuel pump relay and still geting this problem ..any ideas its got my head done right in :angry:
Offline mattkh
Re: fuel pump not primeing
« Reply #1 on: 08 March 2009, 10:28 »
Hi
Try a new ignition switch.
Offline 0191joe123
« Reply #2 on: 08 March 2009, 16:21 »
got 1 on mate just changed it 2 mounth ag
Offline mattkh
« Reply #3 on: 08 March 2009, 17:54 »
Hi
In that case, how old is the coil and what about the crank sensor.
« Reply #4 on: 08 March 2009, 18:38 »
If the fuel pump is not priming and you have replaced the relay then maybe you have an ECU or pump problem.
jamie16v
« Reply #5 on: 08 March 2009, 19:02 »
seconded..
test it first, bypass the ecu and put a 12v straight to the fuel pump relay, if it still happens its the pump... if it doesnt then it could be the ECU..
« Reply #6 on: 08 March 2009, 19:39 »
could be a fault with ign switch or ecu relay
Offline 0191joe123
« Reply #7 on: 08 March 2009, 20:17 »
hi mate it will prime eventually just need about 10mins turning ignition on an off ,av changed the fuel pump relay and ignition switch about a month ago ,havent changed the ecu relay do u think i shud try
jamie16v
« Reply #8 on: 08 March 2009, 21:48 »
its deffo worth trying.. but i would try and diagnose the fault first...
Offline 0191joe123
« Reply #9 on: 08 March 2009, 22:19 »
yeh mate av got vagcom just not the cable yet ,looks lyk its time to buy 1
