Author Topic: camber/ tracking settings mk3 gti Recommendations please!  (Read 3863 times)
Offline boneybradley
  • Back in a Mk3...
Finally i am getting my tracking and camber adjusted tommorrow and I would like to know what people recommened? I have heard adding -1 degree camber up front will make it handle better...Is this right??
Oh yeah a mate is sorting this at his work (they don't do many modified cars but he runs an uber low polo and he's set that up!!) and its costing me all of £25  :cool: :cool:
Offline Khare
  • The bear that khares
Re: camber/ tracking settings mk3 gti Recommendations please!
« Reply #1 on: 07 March 2009, 21:05 »
yup -1 camber is what DH recommended for me to use on the road, -2 if your using it on a track though.
« Reply #2 on: 09 March 2009, 08:53 »
I ran mine at standard settings.
Offline Diamond Hell
  • Opinions я Us
« Reply #3 on: 09 March 2009, 09:11 »
-1 camber will give you keener turn-in.  If you do a lot of motorway driving you may find the inside edges of the tyres wear slightly faster as the wheels aren't square to the ground.
Offline Khare
« Reply #4 on: 09 March 2009, 21:07 »
DH set me up with -2 atm and its pretty hard to keep it in a straight line. deffo keener to turn in and steering is much lighter and it seems to want to stay cornering rather than straighten up. Going for -1 when i get the wheels aligned properly.
  • Back in a Mk3...
« Reply #5 on: 09 March 2009, 21:14 »
well its set to -1 and she does turn in faster and grip that bit more (but tracking is not 100% yet as we had issues with getting the rear on the machine and they did there best with the readings it gave!! it is going back next weekend so they can have another play!)
  • Opinions я Us
« Reply #6 on: 10 March 2009, 08:34 »
I'm not sure how much they'll be able to do with the back end. For you 2WD boys the back end's pretty set IIRC.
« Reply #7 on: 10 March 2009, 09:23 »
aye at the back there isnt really any adjustment. the only thing you can do is unbolt the stub axles and bodge washers behind, or get a camber shim kit which allows more precise adjustment of both toe and camber.  'EZ Shim' are generally recommended and pretty cheap too.
Offline danny_p
« Reply #8 on: 10 March 2009, 19:54 »
washers  are really bad news.   if drive hard can cause fail of bolts holding stub axel on.   shims are ok
all the VW's have gone bar 1.
Offline Teutonic_Tamer
« Reply #9 on: 10 March 2009, 20:17 »
Can you alter the castor angle, 'cause this is a good setting to increase by between ½ and 1½ degrees.  A castor angle increase basically improves the self-centering of the steering, and therefore improves straight line stability at speed.  And it also gives the steering more feel on turn in.
I feel like a homo
