Author Topic: Top mounts / top plate.  (Read 1557 times)
Iwan
« on: 07 March 2009, 09:10 »
When the car is on its wheels and fully weighted how much of a gap is the norm for the top clamping plate off the chassis. During my weekly oil check this morning noticed a gap of around 4 to 5 mmm on both sides which I have not noticed before. Is this normal or do I go for new top mounts??
thanks
Offline shepgti
Re: Top mounts / top plate.
« Reply #1 on: 07 March 2009, 09:44 »
i would be worried if the gap wasnt there before and you havnt removed the suspension.. however there is around a 3-4mm gap on mine after fitting coilovers and new topmounts which is normal..
Offline boneybradley
  • Back in a Mk3...
« Reply #2 on: 07 March 2009, 11:20 »
the top mounts/cups are designed so if you get some "lift off" the metal cup dosen't bottom out on the inner wing causing damage (3-6mm in normal)
Offline Ashley
« Reply #3 on: 07 March 2009, 11:37 »
have you changed the suspension at all? vr6 top mounts gave me more clearence to standard
Offline faz186
« Reply #4 on: 07 March 2009, 13:09 »
ive noticed that on 1 side of mine has more gap than the other side, fink need to change the mounts
faz
« Reply #5 on: 07 March 2009, 17:18 »
Any gap means the mounts are on the way out.
Offline shepgti
« Reply #6 on: 07 March 2009, 17:44 »
 :huh: so why would new mounts give a gap then? including vr6 ones?
Offline Andy-H
« Reply #7 on: 07 March 2009, 20:43 »
Mine are new VR6 ones as well and I have a gap. I thought this was normal  :undecided:
'02 A4 Quattro sport - gone
'91 Tornado red Mk2
  • Back in a Mk3...
« Reply #8 on: 07 March 2009, 20:46 »
they do have a gap....and as i said before 3-6mm between the metal cup and top inner wing (and the cup must have the rubber sleeve otherwise they can bang!!)
Offline Khare
  • The bear that khares
« Reply #9 on: 07 March 2009, 20:52 »
my gap is about 10mm, but thats cos top mounts are phucked. Changingthem tomorrow hopefully  :smiley: :smiley: :smiley:
