Author Topic: Forge 5 Piece Boost Hose Kit Group Buy Feeler  (Read 55743 times)
Offline sambo
Re: Forge 5 Piece Boost Hose Kit Group Buy Feeler
« Reply #190 on: 20 March 2009, 16:47 »
Yep thats pretty awkward!. It fit's loosly ontot eht urbo but is a very snugg fit on the rigid pipe. I lubed it up a bit with wd40 then got the turbo end on loose. I had to push the rigid pipe end on furth than the stopper ring bit to get it to fit without kinking though.
Awkard as feck to be honest but it does go on afterwards!
Sam
Sam
AXX power!  ..   Tinkering has started.... :smiley:
Offline Hulmie
  • White MK4 1.8T AGU K03s
« Reply #191 on: 20 March 2009, 17:21 »
Do you have pic's Sambo?
Offline sambo
« Reply #192 on: 20 March 2009, 18:10 »
Nah sorry mate, did it late last night after work before it got dark, so was in a bit of a rush!
You just need to wiggle it round untill both connections are on. I found i had to almost bend it in half to get both sides on then pull the rigid pipe side up as far as i could get it so it pretty much touched the small pipe connection which is past the stopper ring bit.
Sam
Sam
Offline Immortal
  • 1.8 Turbo GTI (AUM)
« Reply #193 on: 20 March 2009, 18:17 »
have a look on my dub page I've just done the top 3 hoses (link in my signiture)
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
« Reply #194 on: 20 March 2009, 20:47 »
Yep recieved today cheers!
Fitted the 3 top hoses, the turbo to rigid pipe is a bit of a pain! Had to push it on over the stopper bit on the rigid pipe for it to fit without kinking  :wink:
Will do the intercooler and throttle body pipe on saturday  :wink:
Sam
Ha-ha - It's a right biatch, ain't it??!! :laugh:  I just chopped 10 6mm off the longest side of the pipe! :D
« Last Edit: 21 March 2009, 20:32 by Ivor Mk4 Turbo »
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline sambo
« Reply #195 on: 20 March 2009, 21:08 »
I was going to do that but compared it to the OEM hose and it was the same  :undecided:
OEM hose must just be more flexible?
Inlet and IC hose tomorrow, along with painting brake disc surrounds/spacers black.
Just been touching up my spruced up engine cover, gotta rmemebr to clean throttle body at the same time as IC pipes. !
Then i'm all set for the RR day i think..
Sam
Sam
« Reply #196 on: 20 March 2009, 21:30 »
Sam
Mine was probably about 20mm longer than the OEM item - In fact, i've still got the tiniest of kinks left in the new Forge, but I don't think that's going to harm it, TBH (I hope, lol).
« Reply #197 on: 20 March 2009, 21:31 »
ps  I'm saving the 2 IC pipes until my new IC arrives. :)
Offline sambo
« Reply #198 on: 20 March 2009, 21:33 »
You bought a forge SMIC?  :cool:
p.s You bringing your n75j along for fun?
Sam
« Reply #199 on: 20 March 2009, 21:58 »
Yes, that reminds me......................  I need to phone Nick prior to the RR day to see if he can do anything with it!
