Got a 1.8 20v t that hesitates when driving and idle goes up and down,had it put on a diag machine and came back with 4 intermitent codes
Air flow meter
lambda sensor
fuel too rich bank 1
mapping error cooling system,check thermo stat and temp sensor
the guy cleared the codes and said someone may have been taking off plugs trying to find fault so put some miles on it and come back for another check
I'm gonna start by replacing the temp sensor,cheapest option first and quite a common prob by what I can see.
having a bit of a job getting the right sensor,should have the right one at lunchtime tomorrow so fingers crossed should sort things out
also have a hazzard switch on the way,indicators have stopped working ! I've only had the car a week and everything is going pete tong
brake pad indicator has come up as well now,someone knew when to get rid of their car eh!
any advice greatly needed !
