Author Topic: ABS & Airbag light have come on  (Read 1468 times)
Offline mixedupste
  • I hate bus wayne kerrs!
« on: 05 March 2009, 17:24 »
car has been stood since wednesday morning as took a Q5 home from work. started it this afternoon and both light came on as usual and then stayed on! bit worried about this. can anyone help??? :sad: :sad: :sad:
Offline DEANATRON
Re: ABS & Airbag light have come on
« Reply #1 on: 05 March 2009, 21:48 »
thread on edition about this most probably ABS sensor go to edition 38 mark 3 section under guides - dean
Offline VR6-Joe
« Reply #2 on: 05 March 2009, 21:50 »
Have you tried disconnecting the light, then reconnecting it?
Or disconnect the battery, then reconnecting it?
They're probably the two things I'd try out.
Gone but not forgotten;
1983 Mk1 Golf GX - 1991 Mk2 Golf GTI - 1988 Scirocco Scala - 1989 Mk2 Golf CL - 1993 Mk3 Golf Ryder - 1996 Mk3 Golf SE - 1996 Mk3 Golf CL - 1995 Mk3 Golf GTI 16v - 1996 Mk3 Golf VR6 Highline - 2003 Saxo VTR - 1996 Mk3 Golf VR6
Offline boneybradley
  • Back in a Mk3...
« Reply #3 on: 05 March 2009, 23:40 »
disconnect the battery and whilst its off hige the fuse box forward and feel for any dampness (it's worthwhile remving the plastic wiper arm cover thing and removing any leaves and crap that collects there and also give the drain channels a clean)... and when you reconnect the battery it should clear the codes
Offline mixedupste
« Reply #4 on: 06 March 2009, 08:44 »
I'll do that then tomorrow whilst i'm giving the car a good clean.
cheers people swift response as usual
Offline tdi_blu
  • Golf Gti & T4 2.5 tdi
« Reply #5 on: 07 March 2009, 07:18 »
My abs lights on mine solid took it to a friend who works at vw dealer put it on the laptop rear speed sensiors gone pretty common if you know any local garages with a laptop they may just be able to cancel them out or at least tell you the faults i wouldnt think it be anythink bad mines still on and i use my car daily  :tongue:
Golf Gti
Offline Mikester
  • Civic Type R
« Reply #6 on: 07 March 2009, 19:31 »
Changed right front, and right rear abs sensors today. Becoming a pro at it. Took about 30mins per sensor, inlcuding jacking.
