Author Topic: Not getting hot  (Read 1083 times)
Offline dubber36
Not getting hot
« on: 05 March 2009, 16:57 »
I noticed today that by 16v is not getting up to temperature.
After about 20 miles the temp gauge was only just up to 1/4 and the heater was only pumping out mildly warm air.
Any suggestions?
Josho
Re: Not getting hot
« Reply #1 on: 05 March 2009, 17:06 »
Probably the thermostat. No idea how to change it on a 16v MK2 but it is probably the thermostat.
Offline ozegti
Re: Not getting hot
« Reply #2 on: 05 March 2009, 20:43 »
If it's the same as an 8V, it's located under the water pump, 2x10mm nuts and a bucket if you've got good coolant.
Mine does the same, so I'll be tackling this later this week.
Offline Ben Lessani
Re: Not getting hot
« Reply #3 on: 05 March 2009, 23:47 »
My money is on the thermostat, if not
Mildy warm air = bias valves
Slow moving gauge ?= dodgy temp sensor
Offline dubber36
Re: Not getting hot
« Reply #4 on: 06 March 2009, 07:46 »
According to the Haynes book of fiction, the thermostat is under the water pump.
I'll give that a go first plus some new coolant.
How much antifreeze to water? 50/50 ?
Re: Not getting hot
« Reply #5 on: 06 March 2009, 08:37 »
Could be an air lock.
Offline Ben Lessani
Re: Not getting hot
« Reply #6 on: 06 March 2009, 08:41 »
Depends on he Antifreeze, some have a higher % of ethylene glycol.
It will have mixing instructions on the back as to what % will yield what level of protection.
IMO mix it to -35, then at least if you need to top it up with water, you won't dillute it that much.
