Author Topic: Should a 195 really aquaplane this much  (Read 2164 times)
Offline Llewellyn
« on: 05 March 2009, 09:41 »
Just got my car back from having the driveshaft changed, and driving to work this morning, every tiny bit of standing water was throwing me onto the other side of the road. I havent driven the car in a couple of weeks so cant remember how bad it was before.  The tyres aren't particular special, infact quite cheap jobs, put on to get it through an MOT by the previous owner.
Is this the case with all cheap 195s  (im used to running 185s)?
getting the tracking checked at lunchtime anyway.
Any thoughts would be appreciated
James
Mk2 GTI 16v
Mk2 Scirocco 8v
Offline DarnPB
  • Formerly Darnpistonbroke
Re: Should a 195 really aquaplane this much
« Reply #1 on: 05 March 2009, 10:05 »
The bigger area footprint the tyre has, the less weight per square inch, thus effectively, the less weight on the tyre, so the less penetrative force the tyre has through the water. Cheap tyres do not help and the better more expensive tyres are designed to overcome this problem with the tread pattern design.
But you also say that the drive shaft has been replaced, so the first thing for you to do is to check the wheel alignment. Your wheels may have been already sliding before your little skating expedition across the road.
« Last Edit: 05 March 2009, 10:07 by DarnPB »
Offline sidecarphil
« Reply #2 on: 05 March 2009, 10:18 »
i got 205's on my golf and it doesn't aquaplane any more then any other FWD car i have owned
i would have the alignment set , just incase they had to remove the hub to press the shaft out from the wheel bearing
this would make the camber off and them maybe it would drive like a pig  :grin: :grin:
Offline Ben Lessani
« Reply #3 on: 05 March 2009, 10:23 »
I run 205s or 195s but no aquaplaning - as above, its your tyres/alignment - not the actual width of the tyre, otherwise my pops 295s would be skating all over town.
Get a tyre with a deep V (Rainsports FTW :cool:) and you'll only ever want to drive in the rain :laugh:
Offline sidecarphil
« Reply #4 on: 05 March 2009, 10:30 »
must say though my tyres are Toyo Proxis T1R'S
not cheap poop  :laugh: :laugh: :laugh:
Offline Llewellyn
« Reply #5 on: 05 March 2009, 10:49 »
Those are what i am looking at getting :)
Mk2 GTI 16v
Mk2 Scirocco 8v
Offline sidecarphil
« Reply #6 on: 05 March 2009, 10:51 »
they are AWSOME  :grin: :grin: :grin:
no wheel spin , loads of cornering grip
and i'm hoping they will last a track day at Assen next month  :shocked: :shocked:
Offline Llewellyn
« Reply #7 on: 05 March 2009, 10:52 »
Cool, best price i've got so far is 47 quid fitted :)
Mk2 GTI 16v
Mk2 Scirocco 8v
Offline sidecarphil
« Reply #8 on: 05 March 2009, 13:19 »
thats cheap
what size ??
mine are 205/50/15
and cost me 50 euro plus tax
i fitted them myself
Offline Llewellyn
« Reply #9 on: 05 March 2009, 13:26 »
195/50/15 :)
Mk2 GTI 16v
Mk2 Scirocco 8v
