Author Topic: Fuel filter  (Read 1681 times)
Offline jay cee
  • always in front
Fuel filter
« on: 04 March 2009, 12:03 »
where is the fuel filter on the 1997 AGG ?
thanks
Jon
1997 Golf GTI 8v - Dragon Green
http://www.nwdubs.com
www.rouleur.cc
Offline hollandsd
Re: Fuel filter
« Reply #1 on: 04 March 2009, 12:48 »
i belive its under the drivers side passenger footwell about 8inches from the side of the car, have a look underneath and you will see a large cylinder.
Offline jay cee
  • always in front
Re: Fuel filter
« Reply #2 on: 04 March 2009, 12:50 »
is it easy enough to change? what do i have to do to do it?
www.rouleur.cc
Offline Mikester
  • Civic Type R
Re: Fuel filter
« Reply #3 on: 04 March 2009, 12:55 »
I have a 1997 AGG 8v and its beside the rear drivers side wheel, not at the front :/
Offline Paul86S2
Re: Fuel filter
« Reply #4 on: 04 March 2009, 13:00 »
Yes it should be in front of the rear drivers side wheel.
You will need to undo the bolts on the cover and remove the plastic cover. Remove the front and rear pipe clips then pull off the pipes and fit the new one using new jubilee clips.
Be carefull the old fuel filter will be full of petrol, dont smoke whilst doing this and a good idea to disconnect the battery beforehand.
Paul
Offline jay cee
  • always in front
Re: Fuel filter
« Reply #5 on: 04 March 2009, 13:04 »
thanks, so the fuel wont spill out of the pipes will it?
www.rouleur.cc
Josho
Re: Fuel filter
« Reply #6 on: 04 March 2009, 13:45 »
A little will. Hold them up, make it spill less.
Re: Fuel filter
« Reply #7 on: 04 March 2009, 13:52 »
Remove the fuse for the fuel pump, then start the car, it will stall within 10secs or so, this will release the fuel pressure in the lines.
Do not try to remove the fuel lines without doing this as the pressure in the lines means you getting sprayed with petrol at a great rate.
Offline jay cee
  • always in front
Re: Fuel filter
« Reply #8 on: 04 March 2009, 13:54 »
thanks Wayned, i thought that you must have to do something like that.
www.rouleur.cc
Re: Fuel filter
« Reply #9 on: 04 March 2009, 13:55 »
No worries
