Author Topic: Brake problems - pedal goes to the floor :(  (Read 8626 times)
Offline FSARoyster
« on: 04 March 2009, 07:20 »
Hi Guys,
MK2 Golf GTI 16v 1987.
Last week my brake pedal decided to go practically to the floor before the car stopped which worried me to say the least.  Turned out initially that the left hand rear caliper had seized. I fitted MK3 rear calipers and new pads, the calipers are the later version with the internal spring.  Bleed the brakes and still the pedal went to the floor.  Last night I fitted a new master cylinder.  Re-bleed the brakes, using an eezibleed kit, still the pedal goes to the floor, every now and then the pedal has a bit of hardness, then it goes again.  Hopefully going to get some help bleeding the brakes the two man method tonight or over the weekend.  Meanwhile, any ideas guys?  Are Golfs/GTI's renowned for being gits to bleed?  Also when bleeding the brakes I'm starting from back left, front right, back right, front left, think that's right, but prepared to be corrected :)
Thanks in advance
Rog
Offline DarnPB
  • Formerly Darnpistonbroke
Re: Brake problems - pedal goes to the floor :(
« Reply #1 on: 04 March 2009, 08:37 »
I usually start from at the brake furthest from the reservoir, and make my way round to the closest. I had a similar problem to yours and it took ages to bleed. I ended up applying a slight head of air pressure on top of the fluid in the reservoir to force fluid through the new master cylinder whilst pumping the pedal. Sometimes, there is not sufficient suction within the master cylinder seals when they are dry, to draw the fluid through into the pipes, so the fluid needs to be forced through. Once the master cylinder seals are wet with fluid, the transfer of fluid into the pipes should be easier. :smiley:
Offline FSARoyster
« Reply #2 on: 04 March 2009, 08:41 »
So keep bleeding them and see how that goes?  I've read people mention raising the rear of the car up, and the bias valve needs to be open or shut, can't remember which, but I'm getting fluid out of each caliper, and I can see air in the fluid, but I stop bleeding after 10/20 seconds or so once the bubbles are gone...
Thanks
Rog
Offline Ben Lessani
« Reply #3 on: 04 March 2009, 08:46 »
The bias needs to be fully open.
Offline FSARoyster
« Reply #4 on: 04 March 2009, 12:13 »
OK, I'm not sure what way is open :)
For a start the lever has quite a lot of play in it.  I've seen a picture showing it clamped open with a set of mole grips, but I wasn't able to get a set to clamp it in the same fashion.  I've also read you can wedge it open.  See if this is clear and someone can confirm one way or the other.  The end of the lever with the spring attached, should this end be pressed up as far as it will go to open the valve, or pull it down, which would be working against the spring, either way using a a small piece of wood or equivalent to cause the pressing up or pulling down.  From the picture with the mole grips, it appears that you clamp the end without the spring up towards the car.
I'm confused and just want my GTI to work :(
Thanks again
Rog
Offline Teutonic_Tamer
« Reply #5 on: 04 March 2009, 12:29 »
Two man procedure is best for situations like these.  And bin the ezibleed kit, they really arn't very good.
1st, make sure the load sense valve is set to the loaded position.  And work furthest to nearest, and then repeat.  And get 2 litres of new DOT 4.
Brim the master cylinder resevoir (keep the cap off, it shouldn't need it on - but wrap some paper towel around the base of the resevoir to catch any spills).
Get a spanner on the bleed nipple and a bleed tube in a jam jar - but do NOT open the bleed nipple yet.
Get the helper to pump the brake pedal very rapidly three times - as quick as you can say 'pump, pump, pump' - and on the third pump - keep the brake pedal held down - and tell him not to lift the pedal until you tell him.
Then open the bleed nipple, watch the fluid, and then try to close the nipple again before the stream stops.  Only after you have tightend the nipple, then tell the helper to release the brake pedal.  They need to take their foot off the pedal as quickly as they can - and just let the return spring determine the pedal return (don't use your foot to 'slow down' how fast the pedal comes up).
Then repeat the above - about 15 cycles on each corner.  Check and top up the resevoir after every 15 pumps (never let it go below half level).
Then work your way to the other three wheels.
Once all this is done, if there is still any doubt, go round each corner again.
This is the best way of bleeding 'problem' systems which I have used - because the 'pumping' before opening the bleed nipple will actually compress any trapped air, and force it along.
HTH
I feel like a homo
Offline FSARoyster
« Reply #6 on: 04 March 2009, 12:55 »
Firstly, thanks for the in depth explanation.  However, some questions :)
"load sense valve" is this the same as the bias valve/Brake pressure regulator?  If so, using my poor explanation above, which way would be deemed loaded/open?
I've also read that when using the 2 man method, pushing the pedal as far as it will go can burst the seals, or something to that effect, not sure what seals; caliper, master cylinder, who knows, is it worth putting an object between the pedal and floor of the car to stop the full travel of the pedal?  I guess potentially this will ever not allow the air to be pushed out of the system so effectively if at all?
Thanks again
Rog
« Reply #7 on: 04 March 2009, 13:51 »
OK, I personally arn't familiar with the specific set up on the Mk2 (but maybe some of the other Mk2 regulars can confirm).
However, on all cars, irrespective of make/model/type - they have to have a way of limiting or reducing the hydraulic pressure to the rear brakes.  On a non-ABS car, this is usually done in one of two ways.  The simplest and cheapest method (so that is what Fqrd used  :rolleyes:) has a simple 'fixed rate' pressure limiting valve - so when a certain fixed pressure was reached, no more increase in pressure was applied to the rears, even if Arnie pressed the brake pedal with all his might.
The second method uses an 'adjustable' valve which can vary the pressure in the rears, dependent on vehicle loading.
The best way to manually identify which you have, is to simply follow the metal brake pipes from the rear wheel, under the car.  If the pipes pass through a fixed metal piece (which looks like just a large pipe union) - there may be two if your brake circuit is diagonally split - and then goes toward the front master cylinder - then that is the first type (the fixed rate pressure limiting valve) - and there is nothing you need to do with these.
However, if the valve appears to have a metal 'arm' coming out of it - which looks like it could move, then that is probably a variable rate load sense valve.  The main body of the valve should be bolted directly to the floor pan (or other object which doesn't move), and the end of the rod will be linked to a suspension arm, or the rear suspension beam.  If you have one of these, then unhook then end of the rod, and temporarily 'wedge' the arm upwards, as though mimicing the suspension when fully compressed (as though you had 20 bags of cement in your boot).  A couple of warnings though - don't leave the wedge in once you have finished the bleeding, cause if you do, and drive with it there, the first time you hit the brakes, the back end is likely to overtake your front end.  And the other warning is that these are prone to seizing up.  So if you bend the arm, but there appears to be little or no movement in the actuating pistion in the valve, then consider replacing it.
Hmmmmm.  Yes, I agree that if the master cylinder is worn, then using the full pedal stroke may tear one of the seals.  However, if this were to happen, I would honestly be thankful that it let go whilst you were bleeding - rather than getting sudden and unexpected brake failure the next time someone steps out into the road.  This would only affect the seals in the master cylinder, and not the caliper or wheel cylinder seals.
And using a block under the pedal wont work.  Because on braking systems which use 'dual circuits', then the master cylinder has two 'tandem' pistons.  So when one circuit is being bled, one of the pistons hardly moves, and the other one travels along its full length (which should be just half the total travel).  And when you bleed the oposite circuit, the opposite happens with the pistons in the master cylinder.  So you really cant help but to use the full stroke.
HTH
I feel like a homo
Offline earlymk2
« Reply #8 on: 09 March 2009, 07:43 »
Dont know if you have sorted the problem yet. I had the same thing with mine. My brake pipes run under the trailing arm and the hand brake cable over the top, this is the opposite to a mk3 and later mk2s. The only way i could bleed the brakes was to take them off the car and hang them off the brake pipe. With some wood inbetween where the disk should be and help from a mate i bleed the rear and then all was good. Not sure if yours is the same but hope this might help if is not already sorted.
Offline FSARoyster
« Reply #9 on: 16 March 2009, 17:25 »
Well I gave up in the end and took it to a local garage.  He managed to fix them.  He noticed I had the 'wrong' calipers, which I explained to him when I went to collect the car.  He then pointed out to me that I'd actually put the left on the right and vice-versa, but there on and the car now stops, he said I'd probably get better stopping performance if I were to put them on the right sides, but I'm afraid to ever touch brakes again, except for pads, and discs...
Thanks again guys
Rog
