Author Topic: VW R32 Detailed  (Read 6195 times)
Offline Gleaming Kleen
VW R32 Detailed
« on: 04 March 2009, 00:52 »
First up was to wash the wheels using Bilberry wheel cleaner and an assortment of brushes
Engine bay and door shuts were cleaned with P21S TAW
Vehicle was then foamed with Citrus degreaser and worked into all panel gaps, badges and then rinsed off and given a second foaming
Vehicle was then washed with a lambs wool washmitt and Megs Shampoo Plus and rinsed.
All lower sills were sprayed with AS Tardis and gently wiped with a microfiber to remove any tar. Vehicle was then clayed using sonus Green and megs last touch as lube
vehicle was then dried and paintwork inspected. Light swirling and Random scratches were present on all panels. Tried to capture the defects but struggled to get any decent pic's due to colour. The pic below was the best one i had which shows some of the defects present
As defects were minor only a single stage machine polish was needed so after trying a couple combo's I settled on using a Megs polishing pad and Swissvax Cleaner Fluid PRO. This removed all the defects and left the paintwork with a high gloss.
Swissvax Divine was used for protection
Divine was left to cure for a hour whilst i started on some of the smaller jobs
Exhausts before
After
Wheels sealed with zaino Cs and tryes dressed with Swissvax Pneu
Exterior trim dressed with Megs all season dressing
Divine was buffed and paintwork was given a final wipedown with Swissvax Quick Finish
thanks for looking
Jay
« Last Edit: 04 March 2009, 00:57 by Gleaming Kleen »
Offline vaughn
  • now team wagon, and team grumpy trainee
Re: VW R32 Detailed
« Reply #1 on: 04 March 2009, 01:40 »
looks a great job  :smiley:
57 plate black 5dr ed30, 1969 bay window devon camper. thats all for now folks, hopefully picking up a wagon tomoz
Offline xAx
  • lolwut
Re: VW R32 Detailed
« Reply #2 on: 04 March 2009, 10:47 »
What did you use on the exhausts?
Offline Envy Valeting
Re: VW R32 Detailed
« Reply #3 on: 04 March 2009, 15:30 »
Lovely job Jay;)
www.envyvaleting.co.uk
Brazilian waxing since 1999. Online shop open.
Re: VW R32 Detailed
« Reply #4 on: 04 March 2009, 16:37 »
00 steel wool and autosol
« Last Edit: 05 March 2009, 19:41 by Gleaming Kleen »
Re: VW R32 Detailed
« Reply #5 on: 04 March 2009, 16:37 »
Offline northeast_gti-t
  • "1.8T AGU"
Re: VW R32 Detailed
« Reply #6 on: 05 March 2009, 14:32 »
awesome job  :wink: the R looks absolutely stunning  :cool:  :cool:
2000 Mkiv GTi 1.8T AGU
Offline AlanD
  • MK5 2.0T 16v
Re: VW R32 Detailed
« Reply #7 on: 05 March 2009, 15:17 »
0000 steel wool and autosol
Cant really do much of a search now as im at work (busy as you can see ;) ) but where can that wool and autosol be purchased from? I need to get mine looking like that.
Fantastic job by the way, car looks better than it did when I came out the factory  :cool:
Offline stealthwolf
Re: VW R32 Detailed
« Reply #8 on: 05 March 2009, 19:27 »
Autosol from halfrauds. They also do wirewool but it comes in a pack of a mixture of grades.
Jkctr
Re: VW R32 Detailed
« Reply #9 on: 05 March 2009, 19:34 »
Here you go mate
http://www.cleanyourcar.co.uk/accessories/-00-wire-wool/prod_377.html
