Golf mk1
Mk1 Cab
Topic: Mk1 Cab (Read 2311 times)
dwaynedibbly
Just got here
Mk1 Cab
12 July 2004, 07:15 »
Does anybody know if 3-point seatbelts (shoulder-strap) can be fitted to the back of an '88 GTI Cab??
Did the last-of-the-line Rivage/sportline editions come with them as standard??? - I'm not sure on the law requirements at that age of car.
Mine currently has lap-belts which you cant fasten a child seat to!
Please Help!!!!! Cheers.
AdamB
The Perfect Storm
Re:Mk1 Cab
12 July 2004, 07:59 »
I cant see how it would be possible, as there is not a secure mounting point anywhere for the top of the belt to go.
I have have securely mounted a childs seat into the front of my cab before though.
I don't own this anymore - I just can't be arsed to change the picture
gibby
Forum addict
Champions of Europe,ooh ,just the five times then!
Re:Mk1 Cab
12 July 2004, 14:19 »
Mine's a J reg Rivage and I've got lap seats in the back of mine from standard, child seat goes in the front on mine.
Have to agree with Adam about a secure mounting point as I can't see where you'd put it.
......now officially dubless.
danhock
Re:Mk1 Cab
12 July 2004, 14:46 »
Agreed too...
Child seat mounts in front. When they get older (mines 4) the rear lap belts are fine (IMO).
All opinions expressed in this mail are wholey owned by danhock and are not representative of golfgti.co.uk or it affliates.If you disagree with my comments please note that i do not give a f**k ?2005
vixteris
Re:Mk1 Cab
12 July 2004, 16:23 »
the britax freeway child seat only needs a lap belt. i thought most car seats did nowadays although its about 3 years since i bought my one
M17 KVN
Re:Mk1 Cab
23 July 2004, 20:15 »
Im no mechanic but could it not be bolted to the floor in the boot?? Just an idea. Or does it have to be above the height of the seat??
Fitlike!!!
AdamB
The Perfect Storm
Re:Mk1 Cab
Reply #6 on:
23 July 2004, 20:20 »
There must be some legality as to where you can attatch it. I would have thought that the mounting point should need to be re-enforced to such a degree that a sudden pull, as in a crash, would not wrench the bolts out.
carrie
Here all the time
i can see into your soul and its not good
Re:Mk1 Cab
Reply #7 on:
26 July 2004, 20:56 »
a thick plate on the opposite side of the pannel would spread the load and prevent this.
my mk1 escort had a 70mm square plate of aprox 4mm thickness on the inside of the inner sill to acheive this.
the problem with lap belts is as the upper toso goes forward the lower toso does not resulting in the possibility of ripping the internal organs and causing an internal heamorrage killing the person although they look ok externally, this has happened. have a nice day and belt up!
SAY YOU LOVE SATIN?, NO SATAN, ITS SATAN
vixteris
Re:Mk1 Cab
Reply #8 on:
26 July 2004, 21:56 »
or in the case of your normal 3 point harness u might just get a sideways impact resulting in a fractured skull when u hit the roof.
A decent race harness is ur best bet, similar to a child seat
Golf mk1
Mk1 Cab
