Author Topic: My new gti not all good- Cooling fans needed, where from??  (Read 1993 times)
Offline donny_daz
Hi guys after hearing a vibration from my cooling sytem ive found both the fans behind the radiator to be damaged. caused by what looks like the air box above coming loose and falling into them. Ive had a quote from volkswagon for £169 and £108 and thats just the fans no surround etc. Ive found a blokeon ebay who has some from an 07 plate and he says they fit where as ive also been told there are 5 to 6 types. Any ideas guys as my new volkswagon is stressing me out already.
Offline Gene Hunt.
Re: My new gti not all good- Cooling fans needed, where from??
« Reply #1 on: 03 March 2009, 15:14 »
Bad news mate on a new car  :angry:.How old is it ?.Dealer or private sale ?.
Candy White ED35.
Offline donny_daz
« Reply #2 on: 03 March 2009, 16:04 »
bought it private, got it cheap so not all bad , should of noticed when i looked at it. just a bit of confusion of which ones fit, volkswagom wont even give me a part code and i cant get to part to see it.
Offline Gene Hunt.
« Reply #3 on: 03 March 2009, 16:16 »
Can't they tell from the chasis number ?.
Candy White ED35.
Offline ifti
« Reply #4 on: 03 March 2009, 17:57 »
Isnt that covered by warranty?
Offline Teutonic_Tamer
« Reply #5 on: 04 March 2009, 13:20 »
Sadly, it is a known fault, caused by the soft engine mounts used on the GTI.  Technically, this is a design defect, and even if the car is out of warranty, should be covered by the VM.  :sad:
PM me your full VIN number, and I'll look up and give you the correct part numbers for both fans.  You will need to boost your post count first though - as you need a minimum of 10 posts to use the PM facility.
I feel like a homo
Offline redfoot
« Reply #6 on: 04 March 2009, 13:22 »
Ifti - if you are looking for a car I have just put mine in the classifides.
