Author Topic: What would cause a brief loss of power?  (Read 4225 times)
Offline fkgti
« on: 02 March 2009, 12:22 »
Hi guys
Yesterday when i was taking off ther was a loss of power for about 2 seconds when i put it into second gear. Can somebody tell me as to what would cause this? ( 2001 2.0 Gti)
« Last Edit: 02 March 2009, 12:26 by fkgti »
Offline Simpson
  • one day il learn
Re: What would cause a brief loss of power?
« Reply #1 on: 03 March 2009, 11:18 »
fuel filter and electrical fault could be all sorts mate does it do it still?
i must buy a new car!
Offline fkgti
« Reply #2 on: 03 March 2009, 13:48 »
No it just did it the once. Hopefully just a one off !
Offline fkgti
« Reply #3 on: 09 March 2009, 09:45 »
Update: It has now done it again. This time the engine light has come on  :undecided:. I havent drove it since. Should i avoid driving until i get it checked out ?
Offline callum929
« Reply #4 on: 09 March 2009, 09:46 »
if the engine light came on you should get it hooked up to vagcom.
Offline fkgti
« Reply #5 on: 09 March 2009, 20:11 »
I plugged my laptop into it using a cheap cable i got off ebay. It said the following:
Stored Diagnostic Trouble Codes
P0303 – Cylinder 3 misfire detected
Pending diagnostic trouble codes detected during current or last completed driving cycle
P0140 – Oxegen sensor circuit no activity detected ( Bank 1 Sensor 2)
I dont know much about cars. A cylinder misfiring doesnt sound good, Is this a dear repair?? :undecided:
Offline saalro
« Reply #6 on: 10 March 2009, 11:29 »
Hope this helps!
Info from http://wiki.ross-tech.com/index.php/Main_Page. - Ross-Tech (Developers of VAG-COM i believe.)
16687/P0303/000771 - Cylinder 3 Misfire Detected
Possible Causes
Ignition system
Fuel injectors
Fuel pressure
Running out of fuel
EVAP canister purge valve
Evaporative emission system
Low compression
Base engine problems
Controle Module damaged
Special Notes
This feature search for engine misfire in a specific cylinder. Most of the time the cause for a misfire is a lack of combustion in a cylinder due to absence of spark, poor fuel metering, or poor compression.
16524/P0140/000320 - Oxygen (Lambda) Sensor B1 S2: No Activity
Possible Symptoms
Malfunction Indicator Light (MIL) faulty
Possible Causes
Wiring/Connectors from/to Oxygen (Lambda) Sensor Bank 1 Sensor 2 faulty
Possible Solutions
Check Wiring/Connectors from/to Oxygen (Lambda) Sensor Bank 1 Sensor 2
Check Oxygen (Lambda) Sensor Bank 1 Sensor 2
« Last Edit: 10 March 2009, 11:32 by saalro »
Offline Teutonic_Tamer
« Reply #7 on: 10 March 2009, 17:11 »
But the easiest and first port of call for the misfire would be to check and/or replace the spark plugs.  The fundamentals often get overlooked.  :wink:
I feel like a homo
Offline fkgti
« Reply #8 on: 11 March 2009, 11:01 »
Thanks for the advice guys. Got a mechanic to have a luk at it. He hooked it up to his computer and got the same result i did with my £10 cable, and charged me £20!lol He was going to change the spark plugs but said the ones in it are practically new! He said to drive away at it and itl do no harm. However i want to fix it so i am going to have a go at replacing the lambda sensor. Is this a big job??
« Reply #9 on: 12 March 2009, 18:50 »
But are your plugs the correct spec?  It isn't any good them being new if they are the wrong ones!  :wink:
The lambda sensors can be a barsteward.  Get yourself a couple of cans of PlusGas (don't bother with using WD40 as a penetrant lube - it just ain't good enough on exhausts), and give the lambda regular sqiurts over a 24 hour period.  And ideally, beg/steal/borrow the correct sleeved socket.  And get some band aid (for patching up your knuckles).  :evil:
If you get into difficulties, you know where to ask.  :wink:
I feel like a homo
