Author Topic: Engine cover removal  (Read 3478 times)
neo66
« on: 02 March 2009, 12:00 »
Any input on the procedure of taking the plastic engine cover off please?
Dont fancy breaking anything by pulling to hard.
Thanks in advance peeps!
Offline bacillus
Without traction power is nothing!
neo66
Re: Engine cover removal
« Reply #2 on: 02 March 2009, 12:09 »
Brill, ta.
Offline Teutonic_Tamer
« Reply #3 on: 02 March 2009, 12:16 »
http://www.golfmkv.com/forums/showthread.php?t=365
And when the cover is off, smear a thin layer of silicone grease over the four posts and rubbers.  Do NOT use any petroleum based grease, such as copper grease, moly grease, or general wheel bearing grease - because it will rot the rubbers.  If you havn't got any silicone grease, then log onto www.Cromwell.co.uk, find your local branch, and get an 85g tube of Rocol Aqua-Sil - for a 'home user' a tube will last ages.
EDIT: download the 2009 Cromwell pdf - http://www.cromwell.co.uk/images/publication/pdf/cat2009/07.pdf - page 1290 (bottom right) - product code ROC-770-6140Q - £10.60 (plus Darlings dibs)
« Last Edit: 02 March 2009, 12:24 by Teutonic_Tamer »
I feel like a homo
Offline bacillus
« Reply #4 on: 02 March 2009, 12:17 »
Just be sure to lube the rubbers before you put the cover back on as it then makes any futher removal much easier.
Offline bacillus
« Reply #5 on: 02 March 2009, 12:18 »
lol, beaten about the lube part by TT.   :smiley:
Offline AlanD
  • MK5 2.0T 16v
« Reply #6 on: 02 March 2009, 12:44 »
TT is always first in with the lube ;)
« Reply #7 on: 02 March 2009, 12:59 »
PMSL
You don't wanna be inserting it into a dry hole!  :shocked:  :shocked:  :evil:  :evil:
I feel like a homo
neo66
« Reply #8 on: 02 March 2009, 15:29 »
Sounds like you guys are experts in the lube department  :laugh: :laugh:.
Ok, cheers guys.
