Author Topic: rear badge  (Read 1282 times)
Offline forzanerazzurri
rear badge
« on: 11 July 2004, 07:18 »
anyone know the best way to go about changing a badge on the rear (stuck on)  i wanna change it but dont know how to get the old one off and put the new one on without damaging paint
'85 MK2 GTI BIGBUMPERS NeuspeedTurbo/SportSprings,Lowered 2"on15" BBSw/NittoTyres, PortPolish, Bored, 16VThrottleBody, NeuspeedShortShift, DubspeedBigBoreIntake, SwayBar, Racing
Fielder5757
Re:rear badge
« Reply #1 on: 11 July 2004, 11:36 »
Ohhh a long time since i did this one. If i rember rightly, If you look in the boot of the car directally behind the door you will see two little claw like things stuck to the back of two plastic sticks that are attatched to the badge, If you take off the rubber claws you can pull the badge out, Then just slot in the new one and re-apply the claws.
Re:rear badge
« Reply #2 on: 11 July 2004, 22:27 »
my gti badge is just glued on?
Offline philadams16V
Re:rear badge
« Reply #3 on: 12 July 2004, 13:57 »
The best way to take the GTI badge off is; get a flat headed screwdriver, cover the tip with cellotape - this will prevent damage to the paintwork.  Use it to prise off the badge.  To re-fix go to halfords and get some thin double sided sticky pad.  Comes in a roll.  The badge should have 2 clips on it which afix into the bodywork but put a few strips of tape on there as well.  Its very strong and will not mark the paint like superglue and others like it.  Hope this helps.
« Last Edit: 12 July 2004, 13:58 by philadams16V »
