Author Topic: Steering  (Read 1208 times)
Offline jamesg1990
  • 18 and on his second Golf GTi!
Steering
« on: 01 March 2009, 21:25 »
I've had a good look through the forum and can't find the answer to this question....however apologies if it's come up before!
I've got a creak in my steering. It happens during normal driving when I turn the wheel, yet does not happen when the car is stationary and the wheel is turned. The car doesnt make any noises on full lock. I've had the steering looked at for too much play and it seems ok. The suspension seems fine, I can push the front down and it springs back up and settles nicely.
Anyone had the same problem/got any ideas?
Offline sambo
Re: Steering
« Reply #1 on: 01 March 2009, 21:35 »
From the front? Anti roll bar bushes are worn by the sounds of it mate, get um looked at  :smiley:
HTH Sam
Sam
AXX power!  ..   Tinkering has started.... :smiley:
Offline jamesg1990
Re: Steering
« Reply #2 on: 01 March 2009, 21:41 »
HTH Sam
Ok, I'll get them checked out this week. Do you know how much they're likely to cost?
It's a really odd problem, it seems as if the creaking/knocking is almost coming from within the steering column.
Offline sambo
Re: Steering
« Reply #3 on: 01 March 2009, 21:47 »
Bushes aren't much i and an hour or two's labour i should imagine mate. Common problem on ze golf, worth a check  :wink:
Sam
Sam
Offline jamesg1990
Re: Steering
« Reply #4 on: 06 March 2009, 18:52 »
Update on this.
Taken car to garage, they say the ARB bushes are fine. It's actually a bush in the steering column. They said it's unlikely I'll be able to get the bush on its own, so it looks like new column time.
I've had a look on ebay and have found a couple but wasn;t sure if they would fit.
http://cgi.ebay.co.uk/GOLF-MK4-GTI-V5-TDI-BORA-STEERING-COLUMN-LOCK_W0QQitemZ390032268915QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item390032268915&_trksid=p3286.c0.m14&_trkparms=72%3A1683%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318
This one says it would need the barrel switching over, is this easy to do? What happens about the immobiliser?
Anyone know roughly how much a new part would be?
