Author Topic: Central locking  (Read 2273 times)
Iwan
Central locking
« on: 01 March 2009, 20:52 »
To start, what lovely day to take a GTI out for a spin!!!
Bought an alarm for my car, as the imobalizer still works i was just looking for a basic alarm and also would work the central locking. The 'DISTRUCTIONS' are OK but I am struggling to match them up with the wiring diargam on my car. I am trying to identify the loom that feeds the motor switch for the air compresor and the easiet place to tap into them. Hunted high and low and the forum and GOOGLE with no luck!!
Help..........  thanks :embarassed:
Offline LazyLunatic
  • MK3 20VT Project
Re: Central locking
« Reply #1 on: 01 March 2009, 21:05 »
loom that feeds the motor switch for the air compressor? mmmmmm isnt all that stuff in the boot with the pump?
Iwan
Re: Central locking
« Reply #2 on: 01 March 2009, 21:14 »
I thought there would be a switch at each key poss??
thanks
Offline LazyLunatic
  • MK3 20VT Project
Re: Central locking
« Reply #3 on: 01 March 2009, 21:19 »
thanks
if i remember the diagram for the central locking each does have a switch. i thought the main loom for the central locking was on the pump?
adamrob69
Re: Central locking
« Reply #4 on: 01 March 2009, 21:34 »
i was looking into this also, but decided against it as it was a cheapo alarm, and if some chav decided to walk round a car park chancing it with one of these alarm gadgets that runs through loads of unlocking codes then he wud be straight into mine, so decided to leave the central locking out.
however, there are cables in each door you can crimp off, but this would be far too much hassle, so the best place to do it is at the actual pump in the boot, on the plug that connects into the pump there is a pin for a signal to unlock and lock the doors. I cannot remember off the top of my head which pins they were and i think i had to guess at them as the circuit diagrams kicking about doesnt give an explanation of the pins for the motor, but you can work it out quite easily
Offline LazyLunatic
  • MK3 20VT Project
Re: Central locking
« Reply #5 on: 01 March 2009, 22:05 »
i wired in a remote kit for my central locking onto the pump loom. easy to do. i used haynes wiring diagram to help.
Offline troublestarter
Re: Central locking
« Reply #6 on: 02 March 2009, 08:57 »
the locking wires can be found in the drivers side sill
grey = lock
green= unlock
the central locking is positive trigger
www.awesomeautomotive.co.uk<br />mobile vehicle security & audio fitting service<br />insurance accredited
Offline LazyLunatic
  • MK3 20VT Project
Re: Central locking
« Reply #7 on: 02 March 2009, 17:41 »
grey = lock
green= unlock
all found in the boot too  ;)  easy access
Re: Central locking
« Reply #8 on: 02 March 2009, 18:38 »
easy access yes but just as good at the front as there is more space to hide the associated central locking relay
Offline Mikester
  • Civic Type R
Re: Central locking
« Reply #9 on: 02 March 2009, 18:45 »
Troublestarter is car a car electronic god, dont doubt his knowledge. lol.
