Author Topic: Keyfobs  (Read 2904 times)
Offline ade1703
Keyfobs
« on: 01 March 2009, 19:29 »
I have an issue were one of my keyfobs, it has stopped working, I assumed that it was the battery had failed so I swapped it for a new one. Problem is it still does not work! The little red led flashes when I press the buttons on the keyfob and thats about it. Has anyone else experienced this kind of problem, do I need to get it reprogrammed at the dealers/elsewhere or am I looking at having to replace it.
Offline matthewsimone
Re: Keyfobs
« Reply #1 on: 01 March 2009, 19:33 »
not to sure mate may just need re-programing but ive lost one of mine and just been qouted £150 for a new one from the stealers so hope you get it sorted via a new program etc which is around £30 so am told anyway matey :angry:
Offline stealthwolf
Re: Keyfobs
« Reply #2 on: 01 March 2009, 19:47 »
How long have you had the car for? And have you driven for longer than 30 mins nonstop?
Offline Rhyso
Re: Keyfobs
« Reply #3 on: 01 March 2009, 19:48 »
needs re-setting then
there is a procedure for the MKIV but i'm not sure if it would work for the MKV  :undecided:
does the keyfob start the car?
Offline ade1703
Re: Keyfobs
« Reply #4 on: 01 March 2009, 19:54 »
Had the car since last May, 17,000 (of my miles) on the clock  since I bought it :laugh: (just gone through 80,000) and plenty of journeys over thirty minutes.
yes the key starts the car !
« Last Edit: 01 March 2009, 19:55 by ade1703 »
Offline Rhyso
Re: Keyfobs
« Reply #5 on: 01 March 2009, 19:58 »
just needs resetting to the central locking then  :smiley:
this is for the MKIV but its worth trying for your car
http://www.golfgtiforum.co.uk/index.php?topic=77197.0
 :smiley:
Offline ade1703
Re: Keyfobs
« Reply #6 on: 01 March 2009, 20:02 »
Cheers Mate I will give it a go and report back, really appreciate your post.
Best I try when I have a few less beers in my system,  :grin:
Offline Rhyso
Re: Keyfobs
« Reply #7 on: 01 March 2009, 20:03 »
yeah a little less beer MIGHT increase your chances of success  :grin: :grin: :grin:
Offline Pintman
Re: Keyfobs
« Reply #8 on: 01 March 2009, 21:52 »
I had the same issue when replacing the battery in the fob.
There is a sequence that you need to do to re-establish the connection.
Off the top of my head, I can't remember it but it tells you in the manual.
Offline ade1703
Re: Keyfobs
« Reply #9 on: 04 March 2009, 20:38 »
 :smiley:
Sorted!! Thanks for this Rhyso it worked a treat. :grin: :grin: :grin:
