Author Topic: BP ultimate 102  (Read 1855 times)
Offline l3w1s
BP ultimate 102
« on: 01 March 2009, 12:06 »
anyone used the bp ultimate 102, it cost me £2.60 a litre and had to put in a code at the pump to fill up with it, £50 for 19 litres and it made know difference at all, its supposed to be high octane track fuel, but load of bollocks if you ask me, i know my car aint a ferrari but thoght i might get something good for a small fortune. lol
Offline ryanr32
Re: BP ultimate 102
« Reply #1 on: 01 March 2009, 12:23 »
what were you expecting it to do?? add an extra 10bhp or make you go faster?? high octane means it burns easier leading to better mpg!
Offline l3w1s
Re: BP ultimate 102
« Reply #2 on: 01 March 2009, 12:27 »
didnt seem like i got better mpg, even if it did it wouldnt be enough to make up for the extra £1.60, dont know what was going through my head, must be alot better on your engine, make it run better or something ?
Offline Ben Lessani
Re: BP ultimate 102
« Reply #3 on: 01 March 2009, 12:30 »
High octane means its less likely to detonate under high heat/pressure - so only the spark ignites it.
If you had a seriously high compression engine - then I'd expect to see a difference, otherwise, I wouldn't expect it to do much.
« Last Edit: 01 March 2009, 12:32 by Ben Lessani »
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
Re: BP ultimate 102
« Reply #4 on: 01 March 2009, 17:47 »
It would take about 3-4 tank fulls for your ECU to adapt to it properly, but then you're not going to run it indefinitely though, are you?!
Stick to Tesco/Shell 99 RON - Will be more than good enough for a road car.
I can't see the point of the 102 RON outside of motorsport, myself.
Or unless you're running a 700 bhp monster, lol!! :D
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline jonnyturbo
Re: BP ultimate 102
« Reply #5 on: 01 March 2009, 17:51 »
yup i agree with ivor
Offline Sean_GT
Re: BP ultimate 102
« Reply #6 on: 01 March 2009, 21:13 »
i only use shell vpower but im sure thats only 97 ron as to the standard 95ron
Breaking 5 door golf GTi 1.8T ask for info
Re: BP ultimate 102
« Reply #7 on: 01 March 2009, 21:26 »
Nope, V-Power is 99 (It's predecessor Optimax, was 98).........................  Normal BP Ultimate is/was always 97. ;)
Offline northeast_gti-t
  • "1.8T AGU"
Re: BP ultimate 102
« Reply #8 on: 01 March 2009, 23:27 »
anyone used the bp ultimate 102, it cost me £2.60 a litre and had to put in a code at the pump to fill up with it, £50 for 19 litres and it made know difference at all, its supposed to be high octane track fuel, but load of nuts if you ask me, i know my car aint a ferrari but thoght i might get something good for a small fortune. lol
£2.60 per litre  :shocked: equates to £11.85 per gallon  :shocked: madness  :lipsrsealed:
2000 Mkiv GTi 1.8T AGU
Offline Max GTI
Re: BP ultimate 102
« Reply #9 on: 02 March 2009, 13:41 »
Madness.............THIS IS SPARTA
25th Anniversary
No. 1117
