Author Topic: Applying Lacquer  (Read 1979 times)
Offline Vdubbster
Applying Lacquer
« on: 27 February 2009, 13:34 »
Hello people
I have just painted a spoiler in dragon green. Im happy with everything up to here.
Now the last time I used Lacquer was ages ago on my jade green polo, this was a disaster.
SO, how should I be applying Lacquer to a plastic spoiler, how many coats, time between etc etc
I have no Idea, from memory last time the Lacquer did not go one evenly and it looked SO SO SO S%^T
Thanks
Offline Ben Lessani
Re: Applying Lacquer
« Reply #1 on: 27 February 2009, 14:29 »
Only tip I can give you is to make sure the paint is HARD before applying lacquer. Can take days/weeks for some paints to fully harden.
Offline boneybradley
  • Back in a Mk3...
« Reply #2 on: 27 February 2009, 14:49 »
my best tip is get it laquered through a spray gun (friendly local paint guy etc).....I have spoken to many painters who say aero modern laquer wont give good results!!
Offline Vdubbster
« Reply #3 on: 28 February 2009, 01:45 »
Yes good point, il try and find a bodyshop  :laugh: not wort ruining it
Offline upfront84
« Reply #4 on: 09 March 2009, 10:27 »
You'll never get the same results from a can as you will a gun. Spray cans use 1k lacquer which sets by letting the vapours run off, spray shops will use 2k lacquer which requires an activator to set.  Its much thicker and gives a 'deeper' finish.
if you are doing it at home make sure the environment is dust free and build the layers up 15- 20 minutes apart, then allow to fully dry - i.e. the following weekend.  rub back with 1500 - 2000 sand paper before using a buffer to bring the shine back, this should still give you a decentish finish although not quite bodyshop standard.
Dust is your biggest enemy
