Author Topic: mk2 gti diff change.....  (Read 3924 times)
Offline Llewellyn
Re: mk2 gti diff change.....
« Reply #10 on: 27 February 2009, 10:28 »
As helpfully as always with your response rubjonny
my hero :P
Mk2 GTI 16v
Mk2 Scirocco 8v
Offline twistedblack69
  • Proud mk2 user and abuser
« Reply #11 on: 27 February 2009, 10:29 »
So if the numbers are bigger what does that mean?? For example...what are the difference's between these gearboxes??
Tranny Code                  FinalDrive 1st    2nd   3rd  4th  5th
AGB, 2Y (16v Close Ratio)    3.67    3.45  2.12  1.44 1.13 0.91
AUG (1.8 8v 90's G/J)          3.67    3.45  1.94  1.44 1.13 0.89
say mine's the bottom one
Offline danny_p
« Reply #12 on: 27 February 2009, 10:41 »
i've managed to snap the mainshaft off in the clutch  before  :evil:
all the VW's have gone bar 1.
Offline DarnPB
  • Formerly Darnpistonbroke
« Reply #13 on: 27 February 2009, 11:47 »
You can always fit the 16v gearbox and change the 5th gear for that out of a 4e gearbox or a toledo diesel. That would drop your RPM down to about 3200 at 80mph, from 4000rpm. I did this on my old 8v. It was great. Saved fuel too, on a run.
« Last Edit: 27 February 2009, 11:50 by DarnPB »
« Reply #14 on: 27 February 2009, 12:05 »
higher numbers mean shorter gears, go back to the site and try out the funky gear calculator :)
from that you can see the 8v AUG has a taller 2nd and 5th gear compred to the 16v 2Y.
danny thats impressive work!  1st time I've heard of that happening, did anything else go pop as well?
DarnPB: not as simple as that I'm afraid, 2y and MK3 2.0 GTI 8v boxes have a different 5th gear setup, which means you cant fit 'normal' 8v gears onto it.  2Y and MK3 GTI 5th will fit a normal 8v box though.  Best you can do on a 2Y box is fit the MK3 GTI 5th to it :)
edit: taller meaning lower rpm at given road speed, so you can get a higher speed in 2nd and 5th using an AUG box than a 2y box :)
« Last Edit: 27 February 2009, 12:47 by rubjonny »
Offline DarnPB
« Reply #15 on: 27 February 2009, 12:10 »
I stand corrected. :smiley:
I dragged a 5th gear from a 4e gearbox and fitted it to my 8v. I didn't know there was too much difference between 8v and 6v gearboxes.
Offline T_J_G
« Reply #16 on: 27 February 2009, 12:15 »
Was  your car at Brands on Wednesday mate?
Offline DarnPB
« Reply #17 on: 27 February 2009, 12:41 »
Who's? Mine? I hope not! I left it parked at the outlaws house with a cover over it a couple of weeks ago...here in Spain! :undecided:
I better go and check see if it's still there!
« Reply #18 on: 27 February 2009, 12:45 »
not a missive difference, what it is the 2Y stylee gear has a groove cut into it, and uses a different circlip.  It'll fit an 8v box no bother using the 8v curclip, but you cant do it the other way as the 16v circlip is a different thickness, and the 8v gear has no groove to properly secure the 16v circlip.  its easier to just look at brokes site, much easirt to see what I meran from his piccies:
http://www.brokevw.com :)
Offline Llewellyn
« Reply #19 on: 27 February 2009, 13:11 »
If you mean me, then yes it was :)
Mk2 GTI 16v
Mk2 Scirocco 8v
