Author Topic: 8v suspension question??????  (Read 1023 times)
Offline Martz
« on: 26 February 2009, 18:38 »
I put some VR6 top mounts on my Rallye when I changed the suspension, I done this because Darren at G-Werks recommended this for the Rallye. Am I right to think that I will be able to use VR6 top mounts on my 8v? I have just bought a second hand set of springs and dampners and will be fitting these on Monday. Any advise would be appreciated.
Offline MarkS
Re: 8v suspension question??????
« Reply #1 on: 26 February 2009, 18:40 »
They will fit.
I don't think it's a straight swap in the same way g60 mounts are, you need a few more mk3 suspension components iirc.
Hopefully someone will be able to tell you which :)
« Reply #2 on: 26 February 2009, 19:12 »
I believe you would need to change the top spring plate as well.
Offline danny_p
« Reply #3 on: 26 February 2009, 23:28 »
i got mk3 top mounts on mine,  tho not sure whitch bits needed just got all bits needed off some mk3 struts
all the VW's have gone bar 1.
Offline Organisys
  • Old and Slow...
« Reply #4 on: 27 February 2009, 13:51 »
Yes. G60 mounts will also fit and are stronger than the standard mounts.
