Author Topic: abf engine on everything off a 1.8kr  (Read 2691 times)
Offline ben harcombe
« on: 26 February 2009, 14:45 »
I've got a 89 16v gti which now has a dead engine i'm struggling to find a 9 or 6a but can get an abf cheap can i simply bolt all my ancillaries on along with inlet fuel system set the timing and c0 and away i go???
Re: abf engine on everything off a 1.8kr
« Reply #1 on: 26 February 2009, 15:11 »
yes you can, I'd leave the ABF alternator & pas pump on if you can, its much better than the old 16v stuff. new clutch + your old flywheel and away you go.  Oh and you need a kr front coolant flange, the abf one bends the wrong way
« Reply #2 on: 26 February 2009, 19:01 »
sweet ive got everything still from my kr lump do the water pumps fit off the 1.8 because that and my alternator are brand new
also my flywheel looks like it got some weird bolts what tool is needed for these? which manifold is needed
Offline danny_p
« Reply #3 on: 26 February 2009, 19:04 »
the abf multivee flat belt system is far superior to normal vee belts, i woudl retain.
but imo  buy an ecu and loom and use all the abf ness
all the VW's have gone bar 1.
« Reply #4 on: 26 February 2009, 19:21 »
im looking for a quick repair at the minute what happens to the wires which bolt next to the dizzy
Offline Conker
« Reply #5 on: 26 February 2009, 21:36 »
« Reply #6 on: 27 February 2009, 12:19 »
kr waterpump will fit an abf and work wioth the abf belt setup, alternator obv you need to swap back to mk2.  but trust me n dan, if the abf comes with the alternator stuff use it!  Can make your moneys back on the alternator easily ;)
i would agree with dan about running it on abf stuff, but its not a quick n easy job.  No harm in chucking the abf in and getting car on the road in the short term then think about abf managment later on!
If you decide to stick with kjet, prep the abf with new gaskets n stuff before you start the conversion and it can be done in a day on your own :)
« Reply #7 on: 12 March 2009, 15:41 »
got the engine last night at last  :smiley: both stripped at the minute do i need to use the oil cooler off the kr as the abf one has 3 sensors or does that not matter iv noticed the abf has a bracket flywheel side at the bottom does this need to come off as im using the 1.8 rod change box so far all the waterpump and brackets are on the abf off the kr plus a new belt+ tensioner and covers can i use the cam cover off the kr as iv had this painted? i ask because the old cover has not got two bolt holes in the middle
« Reply #8 on: 12 March 2009, 16:25 »
leave the oil housing alone, you'll note there is a small sensor with a white colar, this needs removing and fitting to the hole in the back of the head (oil temp sensor for MFA) in the spot on the back of the head there is a blanking plug, swap that into the hole on the oil cooler :)
The extra hole is very handy, it allows you to fit VDO gauges without the need for removing any of the oem sensors, or using a T piece :)
The bracket is for the O2a box to screw into, I left it on as it covers the hole on the back of the gearbox bellhousing. You could take it off and fit the MK2 tin plate if you prefer.
You cant use the KR rocker cover as the gasket face is different :(
the ABF cover has 2 nuts where the KR bolt holes are, these are covered by the 2 plastic bungs. pop these out and the nuts are accessible.
« Reply #9 on: 12 March 2009, 17:11 »
great reply just what i wanted to hear il leave the bracket on me thinks with my 1.8 box which flywheel and clutch can i get away with also does the abf respond well to carbs i think im going to go for them in the long run
