Author Topic: Urgent help required !!!  (Read 2597 times)
Offline davebatt69
« on: 09 July 2004, 07:39 »
Last night My 8v gti digifant broke down.
The car will not run but it is firing ok, I think maybe a fuel pump problem?, i can't hear any noise from the pump when the ignition is on, i have checked the fuse which is ok can anyone help please???
Offline jimbo
Re:Urgent help required !!!
« Reply #1 on: 09 July 2004, 13:07 »
now then matey. you have two pumps in a gti.one under the car and one in the fuel tank. have you checked both? you access the one in the tank in the boot through a black panal held in place with three screws.
You mention the car is firing ok but how sure are you? i have had a similar exsperiance. the sparks looked fine but they wernt! it turned out that the coil was knackered so try a new coil. they dont cost alot!
check your earth strap on the gear box to chassis. if you have a bad earth it will shag the ecu.
digifant can be a very sensitive system at times! (thats posh fo royal pain in the ass!) :D
aye up me duck!
golfvr6
« Reply #2 on: 09 July 2004, 13:56 »
Check that your fuel pump relay clicks when you turn the ignition. Also check for power at the fuel pump with a multimeter.
Blue MK2
« Reply #3 on: 09 July 2004, 14:26 »
a mate had a problem like that. Turned out to be his ECU.
Offline davebatt69
« Reply #4 on: 09 July 2004, 14:57 »
bought a fuel pump relay today, i hope thats all it is, will find out when i get home from work.
thanks for your help all, whereabouts is the ecu on the car? i hope its not that.
cheers
dave.
Offline richandhazel
« Reply #5 on: 10 July 2004, 09:52 »
The fuel pump should prime the system when you switch the ignition on therefore you should here it run for 2 seconds before starting. If that's not the case then follow vr6's advice and check for power at the pump for that initial 2 seconds. If you're not getting power then it probably isn't your pump, check your relay and the electrical circuits surrounding it.
Let us know how you get on ;)
Offline jlo04
« Reply #6 on: 11 July 2004, 16:02 »
[did u get the fault fixed bud had same trouble wiv mine all ok the total faliure waited a bit car started but woudnt tick over rite now car is hesitant on pickup.
wtf do i do now?/quote]
Veedubgt18v
« Reply #7 on: 11 July 2004, 17:05 »
^^^ check you timing, plugs ht leads, rotor dizzie, and check all you vacuum pumps and fuel feed lines are done up, especially the vacuum line to the feul pressure regulator
Offline davebatt69
« Reply #8 on: 19 July 2004, 13:43 »
I sussed it !!!!, some divy has run a wire from the back of the fuse box to the fuel tank sender.
Don't ask me why !!
There it was, a sh!tty scotchlock connector!!
Happy now scotchlock removed.
