Author Topic: Which Gear Oil To Use??  (Read 1928 times)
Offline 1.6mk4GOLF16v
« on: 25 February 2009, 16:10 »
Gonna change the gear oil tomorrow and was wondering which to use?
I was gonna go for Halfords brand, any others readily available or recomended?
1.6 16v AZD
RS8s 225/35/19
Full powerflow decat exhaust
Blanked EGR
Pipercross panel filter
watch this space for the rest...
Offline BigDaveC
Re: Which Gear Oil To Use??
« Reply #1 on: 27 February 2009, 15:48 »
VW stuff or Redline
Offline Teutonic_Tamer
« Reply #2 on: 28 February 2009, 11:15 »
I would personally only use genuine VW stuff - or failing that, speak directly to Castrol Technical department on the phone.  But I would never use any kind of general gear oil, nor a gear oil from Halfrauds, or any of the lesser known or cheaper oil companies.
Because even with genuine VW gear oils, they have over 30ish different types listed - so just like engine oils, it is not a case of 'one size fits all' for gear oils.
If you aint sure which genuine VW gear oil to use, you can PM me your VIN, and I will look up, and supply you the correct part numbers.
HTH
I feel like a homo
