Author Topic: Needing some of you guys expert help please !!  (Read 1033 times)
Offline nikkim53
« on: 24 February 2009, 19:17 »
Helo Again,
Over the last couple of weeks i've been noticing a slight knocking on the rear passenger side when turning hard lock to the left (ok to the right) and when going over small bumps at speed.
Recently its been getting worse and louder, still doesn't affect the drive at all but am starting to get a bit worried about it.
Has anyone any idea what this could be and if this is a big / expesive job or couldit be done in the drive way ??
Thanks     :smiley:
Offline shepgti
Re: Needing some of you guys expert help please !!
« Reply #1 on: 24 February 2009, 19:27 »
is the car lowerd? also have you checked exhaust fittings as it would be easy for this to cause a knocing sound
Offline nikkim53
« Reply #2 on: 24 February 2009, 19:32 »
Nope - almost completely standard but as clean a car as you'll find.
See i was thinking it had something to do with whel bearings or cv joints but knowing absolutely nothing about cars i'm not sure.
Bought the car 3months ago and the guy told me he had changed the back box recently - a bit pissed off really as he'd took the twin exit off and put a single exhaust on (dont think it looks as good) - so do you think it could be something to do with that ???
« Reply #3 on: 24 February 2009, 19:35 »
2 things to check, 1) in fitting the exhaust has he left the clamp touching the back axle or 2) rear top mounts could be worn, not expensive or hard to replace.
Offline shepgti
« Reply #4 on: 24 February 2009, 19:36 »
yea sounds suspect if hes changed the exhaust recently..
Offline nikkim53
« Reply #5 on: 24 February 2009, 19:37 »
Thanks will have a look at it this weekend - anything else to check out for while i'm under there ??
Offline VR6-Joe
« Reply #6 on: 24 February 2009, 20:45 »
My dad said let the kids out the boot :laugh:
On a serious note.. could it be the rear axle bushes? :undecided:
Gone but not forgotten;
1983 Mk1 Golf GX - 1991 Mk2 Golf GTI - 1988 Scirocco Scala - 1989 Mk2 Golf CL - 1993 Mk3 Golf Ryder - 1996 Mk3 Golf SE - 1996 Mk3 Golf CL - 1995 Mk3 Golf GTI 16v - 1996 Mk3 Golf VR6 Highline - 2003 Saxo VTR - 1996 Mk3 Golf VR6
Offline nikkim53
« Reply #7 on: 24 February 2009, 20:55 »
They dont get in this car much - too fecking messy !!
Well if im honest i think its got more to do with the axle or joints or bearings because its a pretty violent rattling / knocking when i turn left !!!
