Author Topic: homemade mk1 golf caddy (4motion 4wd /holset hx40 ,,turbo resto,56k warning  (Read 240647 times)
Offline adaptorman
Work in Nettos? You've gotta be sh!tting me! You should be an engineer or a fabricator!  :shocked:
This project is just brilliant! I keep going back to it coz if there's a problem you just make something else!!! :cool:
cheers nice idea , but like i said its a homemade idea , lke most just go out and buy custom parts , .i.e exhuast manifolds /short runner and custom parts , i make my own and keeps the costs to a minium ,,be nice to have a workshop to do them in ,, thow lol
Offline adaptorman
bit of gernal stripping checking this after to make sure the engine is in decent ,  i was actury suprized when i removed the sump , very clean in there,
checked all the shells mains and oil pump
next rocker and clyinder head removed
checked the bores and there no lips at all  nice clean smooth bores is always a good sign
also decieded i thought id treat myself to a new steel single mass flywheel to do away with all that dual mass crap
just finshing off the homemade headspacer , saves removing other too
Offline adaptorman
bit more homemade modifying this moring made a new headspacer ,
fits a dam treat too
nige_s
working at Netto must be a cover for something?
Offline adaptorman
ru been seroius ? afraid i do , this is just a bit of past time fun really ,one guy in his own litle world lol
finished it off today, im happy with it so its getting thown on lol
quick clean up and check of the head
 found a bit of vw dove blue paint too , lol so addded some to the block
ill get the clyinder all refitted and torqued back up 2moz ,and look work start on stripping my old unit  out ,,;)
Offline adaptorman
had a spare hour to day so thought id prep the head for the low compression spacer and gasket instail first
split the new gasket as i dont need the middle shim
tin of copper sealer
then use copper head sealer on the block
fit the botom layer
then compression spacer
then top part of gasket
then fit the head and torque the head in the correct order
then get some bars to make sure the varible cam pulleys are tight lol and double checking the timing as well
one engine ready for boost ,,
Offline Neo Badness
  • Feet are for pedals
This is an amazing project well impressed just read 1-27!
Great fabricating skillz!! Reinforced my opinion of do it yourself.
I also like how you've kept the caddy practical by retaining the towbar :wink:
Will continue to watch with interest and hope your new engine holds up to the abuse...
Offline adaptorman
nice one glad u like the idea ,,,(carnt beat a towbar lol) it was the sump which causd the problem was starving the oil oilpump ,, grrr othwise it may still have been runing
nige_s
dude haven't you got this fitted and running yet?  :lol: ;)
Offline Neo Badness
It's not much consolation but at least you know what caused it to go pop so can be avoided in future.
I'm loving the metal based lunacy....
