Author Topic: rear sidelight bulb blowing?  (Read 2059 times)
Offline Shady Pioneer
  • graphic designer.
« on: 23 February 2009, 23:25 »
Since December 24th, the bulb on my rear light bulb holder for the sidelight has gone, 3 times. Why?
Josho
Re: rear sidelight bulb blowing?
« Reply #1 on: 23 February 2009, 23:41 »
Check all the connections to make sure it's not arking, and there isn't any water in there is there?
Offline Dec
« Reply #2 on: 23 February 2009, 23:45 »
Which bulb keeps going? :huh:
Offline Khare
  • The bear that khares
« Reply #3 on: 23 February 2009, 23:45 »
POSESSED!
probably some sort of short circuit. Check fuse is right ampage aswell.
  • graphic designer.
« Reply #4 on: 23 February 2009, 23:46 »
No, no leakages. What is arking?
Dec - The sidelight bulb (middle one of the cluster).
The fuse would be in the fuse box? What's the ampage meant to be? And the other bulb hasn't gone in the 12 months I've had the car, and this one has only just started going since Dec :(
Josho
« Reply #5 on: 23 February 2009, 23:53 »
Oh, yeah Dec, he's terrible that guy.  :laugh:
Arking is where a wire is touching and sort of loose, so it sparks a bit. Loose wire basically.
Offline Khare
« Reply #6 on: 23 February 2009, 23:55 »
how would that cause the bulb to blow? If the wire is loose then it would flick on and off rather than blow. Theres gotta be a shortcut in the circuit somewhere or the fuse is wrong ampage, although is fuse is wrong ampage it should blow the other bulb too....worth a check anyway.
Offline Dec
« Reply #7 on: 23 February 2009, 23:56 »
 :rolleyes: I havent done anything!
My drivers side middle rear bulb has a dodgy connection :huh: People keep telling me its blown, then when I get out and look its working. Today when I got out I didnt close the door though and it was out but the door closed slowly behind me and when it slammed, the light came back on :rolleyes:
Don't know why tbh other than maybe a dodgy connector :sad:
Offline Khare
« Reply #8 on: 23 February 2009, 23:58 »
ive got a dodgy connection on my right numberplate light. sometimes it doesnt work, and if i open my boot then slam it closed it works again. need to check the connections.
  • graphic designer.
« Reply #9 on: 23 February 2009, 23:58 »
Bugger, I'll see if the fuse is ok, which one is it?
