Author Topic: Clocks  (Read 1772 times)
Offline carlos85
Clocks
« on: 21 February 2009, 18:20 »
Were all mk2 clocks cable driven? when i got my car it was fitted with mk3 clocks, so it didn't have the cable.
Offline CHRIS_MC
  • GHETTO GHOLFER
Re: Clocks
« Reply #1 on: 22 February 2009, 12:11 »
as far as im aware yes, cable driven with 2 different styles of connectors for the electricals, (pre 89) i think the drivers had a clock instead of a rev counter,
if you had mk3 clocks in ur mk2? did u have a 16v? or vr6 conversion? seems odd
Offline carlos85
Re: Clocks
« Reply #2 on: 22 February 2009, 14:03 »
no it's just a 8v digi. I'll have to take the dash out and see if i can see the cable. Could they of changed the cable so it reads as electrical instead?
Offline CHRIS_MC
  • GHETTO GHOLFER
Re: Clocks
« Reply #3 on: 22 February 2009, 14:29 »
u got a pic?
most vr6 conversions as far as im aware, (mk2 vr6) modify/splice the loom to accomodate the mk3 cluster, do the clocks work?, they really dont look right sitting behind a mk2 dash IMO,
Offline carlos85
Re: Clocks
« Reply #4 on: 22 February 2009, 17:05 »
i don't know if they work, the car wasn't running when i got it. The mfa and oil etc work on the dials. I know that's why i'm fitting mk2's back in :)
Re: Clocks
« Reply #5 on: 23 February 2009, 08:23 »
mk2 clocks are all cable driven, mk3 clokcs use a speedo sensor that drops right into the speedo hole. chances are you dont have a speedo cable, as the MK3 sensor goes in the same hole.
edit: actually i think the digifiz clocks have a speedo sensor?
Offline carlos85
Re: Clocks
« Reply #6 on: 25 February 2009, 00:36 »
is there anyway to tell? there is a cable coming off the gearbox, but can't find where it is behind the dash
Re: Clocks
« Reply #7 on: 25 February 2009, 08:46 »
the speedo cable goes to the back of the gearbox, its the brown one in the pic here, clipped to the lower header tank hose:
Offline carlos85
Re: Clocks
« Reply #8 on: 25 February 2009, 12:51 »
i thought it was the one on the front of the box :shocked: i'll have to have a look
Re: Clocks
« Reply #9 on: 25 February 2009, 13:57 »
thats the clutch cable :)
