Author Topic: Im confused with lowering :s  (Read 1881 times)
Offline richw911
Re: Im confused with lowering :s
« Reply #10 on: 21 February 2009, 17:40 »
For looks im not to fussed on how it handles as im not a fast driver.
I supose ill spend what ever it costs to get sum good springs.
Yeh im good with spaners my uncle also works in a car garage so that helps lol
Where can i get the upgraded roll bar from then mate?
If you are doing it for looks get coilovers.
You may not like the drop on springs - then you cant change it  :wink:
Offline alex77
« Reply #11 on: 21 February 2009, 17:45 »
Thanks mate where could i get the upgraded arb from as i take it you need it for coilovers aswell?
Thanks for your help.
Offline Kerrse
« Reply #12 on: 21 February 2009, 18:35 »
I never upgraded my roll bar , but i did change the springs and the shocks. I think mine is dropped between 35-40mm
Offline sambo
« Reply #13 on: 21 February 2009, 18:57 »
Balance motorsport mate (google it  :wink:)
They do a whiteline front anti roll bar which goes under the driveshaft so eliminates the rubbing. There are other makes about which have larger hoops to go over the driveshaft. I've got the whiteline and it's all good, reasonable price too.
May want to add a rear ARB too to counter act the increased understeer the uprated front bar will add. Depends if you like going round corners fast or not though  :cool:
HTH Sam
Sam
AXX power!  ..   Tinkering has started.... :smiley:
