Golf mk4
Wazzzer
HELP
Topic: HELP (Read 1885 times)
oliver07
golf gti T 200BHP
HELP
20 February 2009, 15:25 »
MY 2001 gti t has had so many faults just been back to the garage hows this for a list
17705
16514
16795
16486
17633
17635
17636
17634
17833
17955
17843
p1435-35-10
17938
17829
17697
the garage has changed the maff all the coil packs dump valve plugs temp sensor
any ideas please
T_J_G
Serious forum addict
Re: HELP
20 February 2009, 15:33 »
Clear them, go for a drive and re-scan.
Rhyso
Global Moderator
Sir Postalot
Re: HELP
20 February 2009, 15:34 »
wish i had a quid for everytime i've posted this link this week
http://wiki.ross-tech.com/index.php/Main_Page
Fire Up The Quattro
oliver07
golf gti T 200BHP
Re: HELP
20 February 2009, 15:55 »
thanks for the fault finder but when they are cleared the car runs fine for a month then they are back need more info as to why please
T_J_G
Re: HELP
20 February 2009, 15:56 »
use the link Rhyso posted.
Rhyso
Global Moderator
Sir Postalot
Re: HELP
20 February 2009, 17:47 »
Quote from: T_J_G on 20 February 2009, 15:56
yep as the link gives you symptoms and possible causes and what to look for
Fire Up The Quattro
Rhyso
Global Moderator
Sir Postalot
Re: HELP
Reply #6 on:
20 February 2009, 17:49 »
and because i'm bored a quick look reveals you got boost leaks, and problems with your lambda (oxygen sensors) and that was looking at the first 2 codes!
Fire Up The Quattro
oliver07
golf gti T 200BHP
Re: HELP
Reply #7 on:
20 February 2009, 18:43 »
rhyso thanks for your help slight problem not all codes are listed but at least we have a starting block.
dai-cymru
1989 MK2 16V
Re: HELP
Reply #8 on:
20 February 2009, 20:24 »
i think you may have a engine loom breaking down with all those codes.
Rhyso
Global Moderator
Sir Postalot
Re: HELP
Reply #9 on:
20 February 2009, 20:27 »
he also has the same pressure drop from the DV code as you too mate
Fire Up The Quattro
Golf mk4
Wazzzer
HELP
