Author Topic: Throttle Body  (Read 3510 times)
Offline so1o
Throttle Body
« on: 06 July 2004, 06:11 »
I have searched high and low for this without any luck. Every throttlebody i have come across is either a two piece one, like an adaptor plate.........or is different on the bottom, bung design stopper for the throttle.
My throttlebody is a single unit with no bung, some one must know what car its from? Corrado?
I have been told i have a 9a engine, also been told bottom end is 2.0 and top is 1.8 and also been told the inlet manifold is the 50mm one......why buy a car you know nothing about. ???
Help plz.
Solo
marcus123
Re:Throttle Body
« Reply #1 on: 06 July 2004, 09:24 »
alreet solo ;)
yeh 9a should be from a corrado or passat, :)
im thinkin about geting thius engine conversion done as it is relatively cheap, can you tell me bout how the car performs,good and bad points etc etc etc.... cheers my man :)
Offline so1o
Re:Throttle Body
« Reply #2 on: 06 July 2004, 17:35 »
Hmmmm where do I start. Its very quick. I had a go at a mk3 vr6 on the motorway and he got out my way at 135, he must have bottled it. Pickup wise its also very good, had a go at a 328i BMW and he didnt get anywhere.
Do you live around me, i can take you out in it if you like?
Solo
Anymore info on the throttlebody people?
Offline mk1
Re:Throttle Body
« Reply #3 on: 06 July 2004, 18:16 »
What do you want to know, if it is a 9A?. Any chance of a picture as I have a 9A in my car and can check it for you.
Steve.
« Last Edit: 06 July 2004, 18:18 by mk1 »
Offline kevin
Re:Throttle Body
« Reply #4 on: 07 July 2004, 00:38 »
 do you mean it only has one butterfly? if so they were a webber conversion and are rare as rocking horse sh1t
regards kevin
dub855
Re:Throttle Body
« Reply #5 on: 07 July 2004, 01:02 »
50mm inlet are from 5 clinter engines audi coupe for example.
Offline so1o
Re:Throttle Body
« Reply #6 on: 07 July 2004, 16:44 »
Here are the pics, sorry about the pics but it was pouring down  :(.
Its not the weber one, has two butterflys, small and large but its a standard one but very different to the ones i have seen.
I was told the 50mm inlets were found in 2.0 16v sciroccos. Which audi, the 2.0 16v ones? or the 2.2 s2's?
Cheers mk1 if you could have a look, anyone tell me anything by looking at the pics?
Really i need to take the throttlebody off and take some pics but this is a weekend job, no time and weathers crap.
Solo
Veedubgt18v
Re:Throttle Body
« Reply #7 on: 07 July 2004, 17:03 »
then it would be a 5 branch manifold, which wouldnt fit on the 4 pot golf engine
the picture on the right is the golf/corrado 9a manifold
the pic on the left is the audi one.
Offline mk1
Re:Throttle Body
« Reply #8 on: 07 July 2004, 19:43 »
Is that a idle adjuster I can see?, if so it is not a 9A throttle body as there is no provision for a idle screw. Looks like a KR one to me (from here :-\ ;)).
Steve.
Veedubgt18v
Re:Throttle Body
« Reply #9 on: 07 July 2004, 20:15 »
i assume you are talking about the photo not my etka rip?
