Author Topic: few questions  (Read 1248 times)
Offline mart08uk
few questions
« on: 19 February 2009, 16:18 »
hey, just few questions.. i have got an after market radio and fitted it, it worked for a while then i took it out and put it back in and now it looks as though its working but no sound at all comes out of the speakers. I have tried another headunit but it still dosent work  :undecided: i looked at the fuse box but i cant see anything that looks asthough it will fix it.. are there any fuses i need to check somewhere else?
also
There is a button next to the drivers seat on the plastic... it has diagram of car on it and some lines, its probobly obvious but i cannot find out what the hell it does  :grin:
the car in question is a S reg mk4
thanks in advanced
Offline T_J_G
Re: few questions
« Reply #1 on: 19 February 2009, 16:20 »
Not sure about the HU.
The button on door pillar is to turn alarm sensors off or on. Useful if you have a dog.
Offline mart08uk
Re: few questions
« Reply #2 on: 19 February 2009, 16:25 »
Oh! cheers mate, its weird though, dont know if its on or off, the light emitted just stays red no change... but thanks  :smiley:
Offline T_J_G
Re: few questions
« Reply #3 on: 19 February 2009, 16:33 »
You could test it, by locking the car with yourself in it move around and If the alarm goes off you're ok.
Offline theshrew
Re: few questions
« Reply #4 on: 19 February 2009, 16:35 »
Well Fook me i dint no about that button or what it did my alarm goes crazy when the dogs in the car lol
How do u no its on or off without actually trying it ?
As for the head unit question. There will be a fuse for it but this will only control the power to the head unit. If you have power to it ie it switches on etc then the speakers should work also. Check the connections on the head unit for the speakers mate see if the speakers are getting a feed to them
Offline mart08uk
Re: few questions
« Reply #5 on: 19 February 2009, 16:41 »
cheers i know that button is hidden well  :grin:. Yeah there is power to the unit it looks asthough its working apart from no sound at all, from any headunit...
Offline theshrew
Re: few questions
« Reply #6 on: 19 February 2009, 16:51 »
See if there is a feed to the speakers then mate. All you need is a test light. If you not got one make one 2 pieces of wire and a bulb.
At your head unit end  Push one wire in the speaker + the other in the - if its getting a feed the bulb will light up. If the bulb lights up ok do the same at speaker end and see what happends. If now the bulb lights up the speakers buggered if not you have a broken wire somewhere from the head unit to the speaker.
Offline mart08uk
Re: few questions
« Reply #7 on: 19 February 2009, 17:13 »
ok cheers, i have a tester ill go try im sure speakers cant be buggered theres lots of speakers in the car...when removing the HU i must of broke/shorted something ...
Offline richw911
Re: few questions
« Reply #8 on: 19 February 2009, 19:24 »
http://www.golfgtiforum.co.uk/index.php?topic=100739.0
The mk4 maintenance + info section has ...........
Well........ loads of info.
