Author Topic: good responce from start  (Read 3691 times)
Offline sharki786
  • GOT BOOST??
« on: 18 February 2009, 22:26 »
Has anyone noticed a good responce from ther car wen its jus been started? & when the temp gets halfway does ur car get slugish?
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline DazVR6
  • mk3 VR6...FEEL THE GRUNT.
Re: good responce from start
« Reply #1 on: 18 February 2009, 23:02 »
Ive heard of this but tbh its not good for your car, keep it under 2000 revs till your oil temp get to atleast 80 degrees.
I read somewhere that some people feel that their cars perform bettr some days and are slugish on others but no one really knows why.
Do you have and induction kit by the way..?
Offline sharki786
  • GOT BOOST??
« Reply #2 on: 19 February 2009, 13:50 »
no its jus a standard box with standard filter but got a direct air intake from under the fod lite. ooops  :embarassed: i did that yday beter not now.
*****MK4 GTI T*****
Offline DazVR6
« Reply #3 on: 19 February 2009, 14:24 »
Ah ok coz i was gonna suggest that maybe your sluggishneess was caused by heatsoak.....is yours a 16v..?
Offline Khare
  • The bear that khares
« Reply #4 on: 19 February 2009, 15:01 »
When its your engine is cold the fuel pressure is higher, so therefore car does feel more responsive. You can get fuel pressure regulators to keep a constant high pressure but without other mods its useless...
And cars are more responsive on colder days than warmer days.
I love driving on a night with the cold dense fog, car runs sweet as a nut.
Cold air = more oxygen
more oxygen = better combustion
better combustion = more power.
Offline danny_p
« Reply #5 on: 19 February 2009, 21:21 »
wtf  are you on about.
proably a lot more likely to be sendor related. or mucky injectors.    all my enignes have allways been keenest when hot  when setup and in good heath
all the VW's have gone bar 1.
Offline Agreeable Slick
  • Unit
« Reply #6 on: 19 February 2009, 22:29 »
As pointed out above, generally wrong, but also:
Cold air = DENSER air, not more oxygen. It just means that the air to fuel ratio goes up ever so slightly, giving a denser combustion area.
Overall it means that the combustion is closer to a stoichiometric value. Still not perfect.
Offline Khare
« Reply #7 on: 19 February 2009, 23:46 »
then why do people do the WUR mod on the mk2? :wink:
and denser air contains more oxygen becuase molecules are packed together. :rolleyes:
« Reply #8 on: 20 February 2009, 08:26 »
On a digi injection car the fuel pressure is always the same, this is maintained by the FPR and temperature does not effect it.
On a k-jet car again the fuel pressure inside the main body of the metering head is always the same, around 5 bar. This is maintained by a pressure relief valve inside the metering head, and is not effected by temperature.
For cold running the WUR actually reduces the fuel pressure to the chamber above the fuel metering pin, allowing it to travel higher for any given air meter flap movement, increasing the fuel volume.  This pressure is gradually increased as the car warms up.
Also the WUR mod reduces the fuel pressure to the pin (warm control pressure), from the factory value of 49-55PSI, to around 48PSI, allowing the pin to move higher, increasing the volume delivered.
« Last Edit: 20 February 2009, 08:27 by rubjonny »
Offline Khare
« Reply #9 on: 20 February 2009, 10:46 »
ahh right. that makes sense now!  :embarassed:
