Author Topic: Non start question...  (Read 5537 times)
Offline overdrive
Re: Non start question...
« Reply #10 on: 19 February 2009, 19:37 »
Cool. Leaving the country on work for a few weeks so will use the supra till im back, that should give me time to source one that suits...
Tommys cars this week include:
**JZA70 Supra for the Wangan Wars
**VW Golf GTI for the complete 80s yuppy package
Offline overdrive
« Reply #11 on: 27 February 2009, 09:03 »
Ok, some research has found these facts:
Golf Syncro 1.8 litre (1P)
 88-91
 Bosch Digifant II
 0 261 200 295
 037 906 022 FH
 XEVD22FH
 88-91
 Bosch Digifant II
 0 261 200 294
 037 906 022 M
 XEVD22M
Golf GTi 1.8 litre 8 Valve (PF)
 87-89
 Bosch Digifant II
 0 261 200 296
 0 261 200 297
 037 906 022 BB
 XEVD22BB
Golf GTi 1.8 litre 8 Valve (PB)
 88-89
 KEN Digifant II
 037 906 022 BC
 XEVD22BC
 88-90
 KEN Digifant II
 037 906 022 AN
 XEVD22AN
 88-90
 KEN Digifant II
 5WP 4 034
 037 906 022 DC
 XEVD22DC
 88-90
 KEN Digifant II
 037 906 022 E
 XEVD22E
 89-90
 Siemens Digifant II
 5WP 4 062
 037 906 022 EN
 XEVD22EN
 88-90
 KEN Digifant II
 037 906 022 F
 XEVD22F
 88-90
 KEN Digifant II
 5WP 4 086
 037 906 022 FJ
 XEVD22FJ
 90 on
 Bosch Digifant II
 0 261 200 298
 0 261 200 299
 037 906 022 N
 XEVD22N
 90 on
 Bosch Digifant II
 0 261 200 298
 037 906 022 DB
 XEVD22DB
So this explains a bit about the ECUs and where they go and why. Age revisions seems the first variance, but whats the difference between PB and PF engines?
« Reply #12 on: 27 February 2009, 10:27 »
PF is a PB engine with a CAT :)
Offline Gloves88
« Reply #13 on: 27 February 2009, 12:02 »
Pretty useful info there buddy...
This info in the maintenance section? If not could be pretty good for furture refrence if it was put there...:)
Offline overdrive
« Reply #14 on: 27 February 2009, 12:14 »
Excellent! That should in theory mean that any PB ECU should be interchangeable? Its a DB initialed one on my non cat gti.
I cant say for sure. It might be but i didnt find it there.
« Reply #15 on: 27 February 2009, 12:52 »
I'm not 100% sure if the plug onm the ECU is the same, even if it is id imaging the PF ecu wont work as well without a lambda?  Or do you mean plugging a PB ecu into a PF car?  If it does fit then you may see an improvement, but if it has a cat it could end up dead from the lack of lambda feedback to ze ecu...
Offline sidecarphil
« Reply #16 on: 27 February 2009, 14:40 »
PB will not work on a PF motor
i tried it
mine is a PF when fitted with a PB ECU there was no spark
think i still got a couple of ECU'S ere from when i was trying to fix mine if you want one :)
i'll stick the numbers up tonight or tommorrow   :wink: :wink:
Offline overdrive
« Reply #17 on: 28 February 2009, 11:34 »
Yea, that would be handy.
Mine is a non cat model with a DB, I'm not wantig to run a cat ECU, im wondering if other non-cat ECU's with different serial numbers will work...
