Author Topic: Turbo fault code help needed.  (Read 7466 times)
Offline dai-cymru
  • 1989 MK2 16V
« on: 18 February 2009, 16:57 »
16622/P0238/000568
From Ross-Tech Wiki
Jump to: navigation, search
Contents [hide]
1 16622/P0238/000568 - Manifold Pressure/Boost Sensor (G31): Signal too High
1.1 Possible Symptoms
1.2 Possible Causes
1.3 Possible Solutions
right got this fault code  16622/P0238/000568 - Manifold Pressure/Boost Sensor (G31): Signal too High
Possible Symptoms
Malfunction Indicator Lamp (MIL) active
Possible Causes
Wiring/Connector(s) from/to Manifold Pressure/Boost Sensor (G31) faulty
Possible Solutions
Check Wiring/Connector(s) from/to Manifold Pressure/Boost Sensor (G31)
Check Manifold Pressure/Boost Sensor (G31)
anyone know how much the sensors are  and where i can get one from or where i can get a wiring diagram as we had to wire this sensor into the ecu loom ourselves anyone had this sensor fail and know symptoms? mine is running quite rich by the smells and is very low on power
Offline richw911
Re: Turbo fault code help needed.
« Reply #1 on: 18 February 2009, 18:51 »
Offline dai-cymru
  • 1989 MK2 16V
« Reply #2 on: 18 February 2009, 20:11 »
Map sensor?
http://forums.vwvortex.com/zerothread?id=4244323
mmmm thought it was the one on the inlet manifold, need rhys to connect vag com up again unplug the intercooler plug an see if the code says open circuit cheers rich :afro:
oh rhyso...........................where art thou my little plug in guru
Offline Rhyso
« Reply #3 on: 18 February 2009, 20:12 »
Map sensor?
sat at home drooling over my new wheels  :laugh: :laugh:
where and when bud :afro:
Offline dai-cymru
  • 1989 MK2 16V
« Reply #4 on: 18 February 2009, 20:15 »
Map sensor?
1pm tommorow?
Offline Rhyso
« Reply #5 on: 18 February 2009, 20:22 »
Map sensor?
1pm tommorow?
meet me in work then?  :smiley:
Offline dai-cymru
  • 1989 MK2 16V
« Reply #6 on: 18 February 2009, 20:24 »
Map sensor?
1pm tommorow?
thats what i was wondering if it is the intercooler map sensor then it shouldnt effect the running so pointing at the TIP
Offline Rhyso
« Reply #7 on: 18 February 2009, 20:27 »
Map sensor?
1pm tommorow?
no worries mate - i'll pack my VAGCOM cable and laptop and see what we can find tomorrow  :smiley:
Offline dai-cymru
  • 1989 MK2 16V
« Reply #8 on: 18 February 2009, 20:33 »
Map sensor?
1pm tommorow?
ta mate hope rich's find is right and it's the intercooler sensor  :smiley:
Offline Rhyso
« Reply #9 on: 18 February 2009, 20:34 »
no worries  :smiley:
if he's wrong we can lynch him when he visits week after next  :evil: :grin: :grin: :grin:
