Author Topic: Mk3 ABF Fault codes - can't find what they mean!  (Read 18450 times)
Offline Dec
« on: 18 February 2009, 09:11 »
Hey guys, Used mikesters fault code reader on my car the other day and had 3 fault codes :undecided:
Ive had a look on the other links to see what they are but it was inconclusive.
Codes I had were:
00523
17978
00285 - think thats ABS because my sensor is unplugged at the moment (new loom on friday)
Can anyone help me out?
Offline Rhyso
Offline Dec
Re: Mk3 ABF Fault codes - can't find what they mean!
« Reply #2 on: 18 February 2009, 11:08 »
Cheers bud :)
As expected 00285 is the front right ABS sensor because its not plugged in atm as im having a new loom fitted on that side:
http://wiki.ross-tech.com/index.php/00285
17978 is to do with the imobiliser which must have been because I had the ignition on but not imobolised :S if that makes sense!
http://wiki.ross-tech.com/index.php/17978/P1570/005488
00523 doesnt come up though :(
« Reply #3 on: 18 February 2009, 11:26 »
on my VAG-COM codse list I have
00523 IAT Sensor - Temp High - Circuit Low - G42 A
00523 IAT Sensor - Temp Low - Circuit High - G42 A
So start with the inlet air temp sensor :)
Offline Dec
« Reply #4 on: 18 February 2009, 11:33 »
Cheers mate :) Is that the one on the airbox? :huh:
p.s could you have a read through this if you get a min and spread some guru magic light on it if possible please :grin: sorry to be cheeky :)
http://www.golfgtiforum.co.uk/index.php?topic=106020.0
Offline Mikester
  • Civic Type R
« Reply #5 on: 18 February 2009, 12:24 »
Thats what it came up with on the reader when i checked the codes against the book... But you reckoned it had been unplugged recently and driven so maybe that fault code was old... :/
Maybe if you slam it some more it will fix it.. lol
Offline Dec
« Reply #6 on: 18 February 2009, 12:36 »
Yer I forgot what you said mate :embarassed:
Hopefully the garage will look at it on friday and see if it does need changing but sounds like it was because I had it unplugged for a day :rolleyes:
Offline Mikester
  • Civic Type R
« Reply #7 on: 18 February 2009, 15:26 »
Either way, it has leather and 16v's so cant be alll bad..... Your car looks like the sex.
Offline Dec
« Reply #8 on: 18 February 2009, 15:34 »
Once yours is all finished it will look better :wink:
Offline Mikester
  • Civic Type R
« Reply #9 on: 18 February 2009, 15:36 »
Dunno, it will look basically the same as yours bar the vento front if im honest.
