Author Topic: funny noise  (Read 1807 times)
Offline The Mighty Elvi
  • I'm better than you today.
funny noise
« on: 17 February 2009, 17:25 »
right,
recently changed the suspension and wheels on the valver, now I get a funny noise that sounds similar to the exhaust rhumble you hear if you remove the sound proofing.  gets louder the fatser I go as well.
Funny thing is that it remains when it turn right, but when i turn left, even just one degree on the wheel, it goes away?  :shocked:
Nothing is rubbing.  and my drivers side CV boot is split,  I thought it might be wheel alignment, but a noise from that would happen all the time.  Wheels are ballanced as well.
any ideas?
ta.
Offline OakeyDoak16v
Re: funny noise
« Reply #1 on: 17 February 2009, 17:29 »
Wheel bearing. :smiley:
Re: funny noise
« Reply #2 on: 17 February 2009, 17:34 »
Which side?  :grin:
Re: funny noise
« Reply #3 on: 17 February 2009, 17:39 »
If it stops when you turn left it's the front drivers side.
Offline DarnPB
  • Formerly Darnpistonbroke
Re: funny noise
« Reply #4 on: 17 February 2009, 17:57 »
Did you lower the car? It could be the exhaust touching the rear beam where it goes over it. As you turn one way, it may swing clear. If this is the case, re-align your exhaust and replace the mounting rubbers.
Re: funny noise
« Reply #5 on: 17 February 2009, 18:32 »
That's what I initially thought.  The car is a lot lower than before.  I thought that maybee one of the rubbers had gone.  It does seem a bit of a coincidence that the noise appeared when I changed the suspension.
I'll have a look.  Thanks DPB
Offline DarnPB
Re: funny noise
« Reply #6 on: 17 February 2009, 20:03 »
No worries. That is what happened to my car anyway. :sad:
Offline Ben Lessani
Re: funny noise
« Reply #7 on: 17 February 2009, 20:53 »
If it stops when you turn left, its the passenger side.
Re: funny noise
« Reply #8 on: 17 February 2009, 21:46 »
No it isn't. When a wheel bearing is knackered it rumbles till you put load on it, so buy turning left your putting the weight on the oposite / right hand side. I know this because i've just changed one on mine that was completely mullared and thats what i found out. :smiley:
Offline Ben Lessani
Re: funny noise
« Reply #9 on: 18 February 2009, 00:23 »
Yes, it is. It rumbles until the load is lifted off it. When you load up a failing bearing, it makes noise, not the other way round.
Obviously the fact yours is fixed after recent bearing change was pure luck or something else.
That aside, I don't think a wheel bearing noise is what the OP was talking about.
« Last Edit: 18 February 2009, 00:26 by Ben Lessani »
